displaying posts 51 to 75 of 141
Pages (6): first .. 2 [3] 4 .. last
Author Subject: Misfire
rob_humphrey
Post #51
Wheres the injector plugs mate
Team Moonstone Big grin
Team Working Aircon
Posted 8th Dec 2012 at 20:26
MCH_GTi6
formerly mch
Post #52
Manifold look for green plugs with white connector
Team Moonstone� Ph3 GTI6
Team Rallye
Posted 8th Dec 2012 at 21:49
rob_humphrey
Post #53
just ordered new lambda aswell incase it might be that also the car smells really rich and did 20 miles to 7 litres of fuel Thumbs up
Team Working Aircon
Posted 8th Dec 2012 at 21:52
Post #54
Unplug the lambda bud car will run without being plugged in
Thumbs up
Posted 8th Dec 2012 at 21:57
rob_humphrey
Post #55
how do you unplug it mate?
Team Working Aircon
Posted 8th Dec 2012 at 21:58
Post #56
Pull the red tab out and it will unplug then.
  • Posted 8th Dec 2012 at 21:59
    rob_humphrey
    Post #57
    meant to say where is it lol
    Team Working Aircon
    Posted 8th Dec 2012 at 22:01
    Post #58
    Down behind the battery box towards manifold
    It's a big ish plug with a red bit that you pull out to disconnect the wire from the plug Thumbs up
    Posted 8th Dec 2012 at 22:03
    pugheaven
    Post #59
    Bloody hell, what's going on with this car, didn't give me any issues at all in the week I drove it Crazy
    Posted 8th Dec 2012 at 22:11
    pugheaven
    Post #60
    I wouldn't bother changing the lambda sensor or anything else until you change that coil, it's going to smell of fuel... It's getting the fuel just not igniting it
    Posted 8th Dec 2012 at 22:17
    rob_humphrey
    Post #61
    that lambda seems to of sorted it partly going to do coils as well but it;s running allot smoother now also just thought id share an epic fail with you as well, unplugged the lambda and took it for a drive went out of my road and couldn't find second gear at all so pulled over and the lambda connector had got jammed in the gear linkage Blush Doh. Olly the cars given me loads of grief LOL nothing serious though. also the exhaust smells normal again not rich Thumbs up
    Team Working Aircon
    Posted 8th Dec 2012 at 22:34
    pugheaven
    Post #62
    Well it is French lol don't think Tom had any issues with it, just bad luck I guess
    Posted 8th Dec 2012 at 22:39
    rob_humphrey
    Post #63
    LOL yeah oh well ill get it sorted seems like the lambda sorted it so gave it bean's to get home and just as i got home it i put it in neutral and it spluttered all over the place and spluttered when i revved it its doing my f**king nut in
    Team Working Aircon
    Posted 8th Dec 2012 at 22:43
    Post #64
    Just change the fecking coils dude Yes
    Try unplugging the power steering sensor as well as that causes all sorts of funny running issues
    It's at the bottom of the front of the engine blue plug - follow power steering lines Thumbs up
    Posted 8th Dec 2012 at 23:03
    rob_humphrey
    Post #65
    Cheers mate ill get them done tommorow hopefully what i really need to know is can i do that test thingy without having to drive it until it misfires ie can i just unplug them while its on my drive without of being driven anywhere will i still hear a difference or do i have to wait for it to misfire?
    Team Working Aircon
    Posted 8th Dec 2012 at 23:06
    Post #66
    Need to have the misfire happening to do the coil thing Yes
    Posted 8th Dec 2012 at 23:34
    rob_humphrey
    Post #67
    Think ive just sussed what the problem is. whilst having a look at the sensor locations i saw that the intake air temp sensor looked different to mine so i went to have a look and on mine someone has twisted it so it point right instead of downwards as a result one of the little plastic bits has snapped off that holds it in position inside the inlet. going to order new sensor Thumbs up also i noticed that the connector to the map sensor has another plug on the same wire thats unplugged is this normal?
    Team Working Aircon
    Posted 8th Dec 2012 at 23:36
    Post #68
    The intake air temp sensor won't be affected because the mounting tabs are snapped off. No
    As for the unplugged plug on the MAP sensor wiring, this is normal it is a 'spare' plug on the loom. Yes
    Posted 9th Dec 2012 at 09:16
    rob_humphrey
    Post #69
    well it wasn't sealing propperly and was hanging off LOL ill take it out later see what happenes
    Team Working Aircon
    Posted 9th Dec 2012 at 09:21
    Post #70
    If it wasn't sealing correctly, it would be sucking in air and therefore would make the mixture run lean not rich. Wink
    Posted 9th Dec 2012 at 10:27
    swiftyboi006
    Post #71
    ^ yep and you would be revving alot
    Black p3 Love
    Posted 9th Dec 2012 at 10:35
    Post #72
    Doubtful given its a small hole and it has a map sensor.
    Posted 9th Dec 2012 at 10:41
    Post #73
    Nope, it would just have a tendancy to stall. Yes
    Posted 9th Dec 2012 at 10:55
    rob_humphrey
    Post #74
    All i can smell under the bonnet if fuel lol deffo coil packs me thinks Sad
    Team Working Aircon
    Posted 9th Dec 2012 at 11:29
    Post #75
    if you can smell fuel under the bonnet you have a leak...
    Posted 9th Dec 2012 at 11:34
