Author Subject: Breaking '6 engine for parts
I've started splitting a ph3 GTi6 engine. The engine has covered 140k but pulls well and isn't a tapper.
Engine loom - £20
Bare inlet manifold - £20
Bare throttle body - £15
Vacuum pump - £10
Exhaust manifold - £15
Cambelt covers inside and out - £15
Power steering belt cover - £10
Map sensor - £10
Thermostat housing with sensors. Bleed nipple has been adapted with a bolt - £15£10
PAS pump - £20
Starter motor - £20
Alternator - £30
Heat exchanger - £10
Fuel rail - SOLD
Fuel pump relay - SOLD
Injectors x4 - SOLD
ICV - SOLD
Coil packs x4 - SOLD
Inertia fuel cut off switch - SOLD
TPS - SOLD
Cylinder head comlete with cams, cam covers etc etc SOLD
Bottom end complete SOLD
Various pipes etc are available, plus whatever I have forgotten. Just ask.
All prices are plus postage.
  • Posted 4th Dec 2012 at 20:55
    Fuel rail and pump relay sold
  • Posted 7th Dec 2012 at 10:13
    ajmckeane
    If the head sale falls through drop me a PM pal
    China's ALIVE !!!
    Posted 7th Dec 2012 at 20:15
    No problem Andrew, will do Thumbs up
  • Posted 7th Dec 2012 at 20:27
    Bump
  • Posted 16th Dec 2012 at 08:56
    Some pics and new bits
    Map sensor £10
    Thermostat housing with sensors. Bleed nipple has been adapted. £10
    Manifold heat shield £8
    Inlet vacuum pipe and t piece £5 each
    Metal water pipes £12 for all in the below pic
    Top rad hose £7
    Throttle body with inlet temp sensor and bracket £15
  • Posted 23rd Dec 2012 at 14:26
    Bump
  • Posted 1st Jan 2013 at 13:26
    Updated list with sold items ammended and new items found since added.
    Bare inlet manifold - £20 Reduced to £15
    Bare throttle body - £15 Reduced to £10
    PAS pump - £25 Reduced to £20
    Power steering belt cover - £10 Reduced to £5
    Vacuum pump - £10
    Map sensor - £10
    Inertia fuel cut off switch - £5
    Thermostat housing with sensors - £15
    Starter motor - £20
    Alternator - £30
    Top rad hose - £7
    Injectors x4 SOLD
    Coil packs x4 SOLD
    Air con pump. NLA
    ICV SOLD
    Fuel rail SOLD
    Fuel pump relay SOLD
    TPS SOLD
  • Posted 6th Jan 2013 at 18:14
    Bump
  • Posted 10th Jan 2013 at 19:43
    Head and bottom end sold.
  • Posted 16th Jan 2013 at 10:49
    Vacuum pump - £10
    Map sensor - £10
    Starter motor - £20
    Alternator - £30
    Top rad hose - £7
    Injectors x4 SOLD
    Coil packs x4 SOLD
    Air con pump. NLA
    ICV SOLD
    Fuel rail SOLD
    TPS SOLD
    PAS pump SOLD
    Head SOLD
    Bottom end SOLD
    Just come across a crank sensor in GWO - £8
  • Posted 27th Jan 2013 at 09:43
    Remaining bits:
    Bare inlet manifold - £15
    Bare throttle body - £10
    Cambelt outer cover - £10
    Map sensor - £10
    Crank sensor - £8
    Starter motor - £20
    Alternator - £30
  • Posted 8th Apr 2013 at 19:36
    jeffers Forum Admin
    Dan, il take the vacuum pump. Any chance you can throw the bolts in too? Pm me payment details! Thumbs up
    Team Running Engine again!
    Team Negative Camber!
    Posted 9th Apr 2013 at 00:19
