Author Subject: peugeot partner/citroen berlingo
martinh
As per title, I'm after a partner/berlingo for my dad has his has just died! Preferably a 2 litre hdi, would consider a straight diesel but definitely don't want a 1.6 hdi!
Let me know if you have/know of one!
Martin
Posted 9th Dec 2012 at 11:39
rich306
Whats wrong with the 1.6 Hdi's then? gutless?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 9th Dec 2012 at 14:19
no, lots of issues.
Posted 9th Dec 2012 at 14:35
rich306
Explain? i'm looking at getting a Peugeot Partner somepoint early next year!
- Top Tip!!!
Posted 9th Dec 2012 at 15:01
Mainly turbo and injector related issues, oftten leading to self destructing.
Posted 9th Dec 2012 at 15:16
martinh
Exactly as welshpug says! as far as I'm aware mainly turbo issues, my mate has a garage and he quite often has either the 1.6 hdi's and ford 1.6 tdci's in with turbo issues, not a cheap thing to put right either.
I'm led to believe that the 2l hdi is a much safer bet!
Posted 9th Dec 2012 at 16:07
miles
Don;t touch a 1.6, I'm not into Derv's but I've seen quite a few of these broken with the garage behind me
www.pugracing.com
Posted 9th Dec 2012 at 18:58
rich306
Oh right, that's interesting. I had a 1.6 HDi Citroen Xsara Picasso in the past, and that was generally ok whilst i owned the car. Something to bear in mind though Smile thanks
- Top Tip!!!
Posted 9th Dec 2012 at 20:05
maybe
The turbo's only go because people cut corners and use the incorrect engine oil. Service history is the key or go new!
Posted 9th Dec 2012 at 20:12
budget?
Posted 11th Dec 2012 at 19:37
pugjim
turbos go due to blocked oil feed return pipes, they should be cleaned/replaced every 40k miles and correct grade engine oil used and changed every 8k miles. Also suffer from egr valve failure and there £200 to buy a new egr valve. Other than that they are a great engine.
Rebuild kit for turbo is around £120 and about 2 and half hour job so not that bad as long as you dont carry on driving them when turbo is on its way out.
Posted 11th Dec 2012 at 21:20
