Author Subject: no brake lights
aaron6
I all, I have none. Anyone got reasons why so I can work my through the possibilities? Smile
Posted 11th Dec 2012 at 07:03
aaron6
If people think fuses, does anyone which one it is?
Posted 11th Dec 2012 at 07:05
Rtfm, its in faq.
Posted 11th Dec 2012 at 07:41
aaron6
Rtfm?
Posted 11th Dec 2012 at 07:57
aaron6 wrote:
Rtfm?
"Read The F****** Manual" I believe...
By the way, I suspect it's actually your brake light switch, not the fuse, but worth checking anyways. Yes
Posted 11th Dec 2012 at 07:58
aaron6
Ah nice...
It's the switch I believe too. Cheers stan. Smile
Posted 11th Dec 2012 at 10:37
No problem.
It can be a bit of a ballache job as unless you have ridiculously small hands it's a steering column drop job. Yes
Posted 11th Dec 2012 at 11:28
aaron6
Hugo has it. Hopefully he's got the time to sort it. I don't that's for sure. Smile
Posted 11th Dec 2012 at 12:29
daver6
Damn, beaten to it. probably the switch. try adjusting it before replacing.
I used a pair of pliers to wiggle the switch in is housing, worked for me
Wishbone Polybushes available
Posted 11th Dec 2012 at 15:43
gilesy
If you don't have child size hands then look forward to looking like you self harm by the time you are finished if you don't drop the steering wheel
Posted 11th Dec 2012 at 15:58
So...
Did the wonder of Hugo fix it then? Dunno
Posted 12th Dec 2012 at 21:42
aaron6
Yep. He done a treat. Smile
He also checked my airbags on the cpu. I have a fault with pretensioner 2. Pug wouldn't say which seat it was. Any ideas as I have 2other known good pretensioners in my old seats.
Posted 13th Dec 2012 at 06:59
Should have unplugged one at a time whilst it was on the diag to flag up which one was faulty.
I guess you could just put both your spare ones in, then you know you've sorted the issue. Wink
Posted 13th Dec 2012 at 07:30
aaron6
This is true. Easy to change?
Posted 13th Dec 2012 at 08:46
Yes mate, they are behind the B-Pillars. Wink
Posted 13th Dec 2012 at 11:32
aaron6
Cool, I'll check my old seats for how to remove them then swap them once I get a chance. Smile
Posted 13th Dec 2012 at 12:40
just whip the plastic casing off the side of the seat, think it's 3-4 torx bolts per side and it'll expose the pretensioner. then it's just a bolt i believe. easier with the seat out, not sure if it's as easy with the seat still in, cos you'll be working close to the tunnel
check the pretensioner hasn't fired, it'll be noticably tugged on the wire and about an inch shorter than usual. i bought some seats once like this, never noticed until a week later when i kept whacking my hand on the seat plugging the belt in!
Posted 13th Dec 2012 at 13:59
aaron6
Thanks for the advise mate. Smile
I'll try it whilst the seats are in. Can always take them out if need be. Smile
Posted 13th Dec 2012 at 15:05
Doh
I just read what I wrote. For some reason I was thinking about the seatbelt rather than the pre-tensioner unit. LOL
Yes, it is exactly like Rikky says, you should manage it ok mate.
Posted 13th Dec 2012 at 15:13
Niall
stan_306gti6 wrote:
Doh
some cars are but not the 306.
pretensioner 2 is the passenger seat i believe Smile
Posted 13th Dec 2012 at 17:20
aaron6
I'll probably change both for 2 known working units. But I thought passenger seat too. Although I'd have expected just the drivers seat or both to have gone. Dunno
Posted 14th Dec 2012 at 07:11
