Author Subject: clicking sound
Demograffix.com
Hi everyone,
I have been experiencing a weird clicking sound which is a lot like the indicator sound coming from around the dash/ steering wheel area/ fuses? not sure what this sound would be, could anyone shed some light on this and what I should do to correct it?Unsure
stevenage black gti 6, 198bhp
Posted 13th Dec 2012 at 21:03
rich306
I've heard of this before, either one of the following:
Faulty Relay
Indicator stalk making constant contact (Vaseline inside the unit making electrical contact)
If it's not them, i'm sure the other guys can give a better hint making me sound like a tard' Thumbs up
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 13th Dec 2012 at 21:08
Niall
need a new indicator stalk mate Smile
Demograffix.com
Faulty Relay
cheers mate, Im not sure what your suggesting? to put vaseline on it and where? lol Im interested to hear some more suggestions. I've recently replaced the green and brown sensors on the thermostat housing waiting on the blue sensor to arrive at the momentThumbs up
Posted 13th Dec 2012 at 21:13
Demograffix.com
cool this sounds about right are they hard to replace/?
Posted 13th Dec 2012 at 21:14
Niall
easy. 3x t20 screws under the steering column shroud, remove the cover, 2 or 3x t15 screws fixing the stalk into the holder then pull it out, unplug and reverse.
Posted 13th Dec 2012 at 21:16
Demograffix.com
Brilliant ill give it a goThumbs up
Posted 13th Dec 2012 at 21:17
Niall
Demograffix.com wrote:
Faulty Relay
mate the blue one only controls the gauge on the dash. no point really in replacing it.
Posted 13th Dec 2012 at 21:18
Demograffix.com
Faulty Relay
even so, Im trying to work my way through any faulty parts. If iv replaced the other two there no harm in it. Just trying to keep my 6 running at the moment gonna spend a bit on it soonSmile
Posted 13th Dec 2012 at 21:23
rich306
Faulty Relay
No, not put vaseline on it lol, it comes out the factory with a lubricant on it to A: keep it moving smoothly and B: provide good electrical contact. Unfortunately over time the lubricant moves making contact with the other metal parts forming a connection... therefore making the clicky sound and sometimes making the indicator lights come on as Hazards.
All you need to do is take it out of the steering column, prise it apart and clean it making sure the vaseline isn't spread across the two contacts. That should sort it, if not it will be a new stalk jobby! Thumbs up
- Top Tip!!!
Posted 13th Dec 2012 at 22:02
Status: Online
http://www.306gti6.com/forum/showthread.php?id=151758
Posted 13th Dec 2012 at 22:03
rich306
Couldn't of been put better Rikky! Thumbs up
- Top Tip!!!
Posted 13th Dec 2012 at 22:13
Demograffix.com
thank you this FAQ looks to
Be very detailed and i will try to follow it as best I canThumbs up
Posted 13th Dec 2012 at 23:34
rich306
The only thing i can say is after removing all the grease, put a smidgen of Vaseline on the runners (very tiny amount) so that it reduces the wear a little bit more.
- Top Tip!!!
Posted 14th Dec 2012 at 07:11
Status: Online
bear in mind it'll conduct again though if you get more bits within it so be careful
Posted 14th Dec 2012 at 08:06
Demograffix.com
How do I open the indicator housing?
Posted 17th Dec 2012 at 12:49
Status: Online
see my faq LOL
small flathead and press the 3x tabs (6 in total, 3 per side) and the top mechanism will remove
Posted 17th Dec 2012 at 12:50
Demograffix.com
Thanks to everyone that offered their support, I took the indicator stalk apart, cleaned and added Vaseline. The condition of it was very dry and worn. The problem is still there so I'm going to buy a new, it's an interest task taking it apart and I'm glad iv learnt something newThumbs up
Posted 18th Dec 2012 at 18:47
rich306
Hmmm, no problem for the help but it's a shame it's too worn for the part to work fully. Sad
- Top Tip!!!
Posted 18th Dec 2012 at 19:42
Status: Online
did you rotate the circular contact as my FAQ says?
Posted 18th Dec 2012 at 19:45
