Author Subject: What size spacers
swiftyboi006
6j et25 off a ford rs2000 4x4 not a clue with wheels
Black p3 Love
Posted 14th Dec 2012 at 21:40
as the original 6" wide wheels are ET19 you'd probably get away with none but the centre bore is too small.
Posted 14th Dec 2012 at 21:47
swiftyboi006
Whats the centre bore? Lol feel like such a dick
Black p3 Love
Posted 14th Dec 2012 at 21:52
63.4 as opposed to 65.1
Posted 14th Dec 2012 at 22:04
simonjames
centre bore is the hole in the centre of the wheel that sits on the hub
an ET25 would need a spacer 7-10mm to achieve an ideal 15-18mm offset
MY EBAY ITEMS
07943066306
Posted 14th Dec 2012 at 22:08
swiftyboi006
What does that mean mr welsh? I just read up on the centre bore and i understand that but if there too small what can be done?
Black p3 Love
simonjames
too small a bore would need the wheel machining out or a hubcentric spacer but you'd need to space past the hub so looking at 25mm+
MY EBAY ITEMS
07943066306
Posted 14th Dec 2012 at 22:13
Naah, you can get 15mm.
Posted 14th Dec 2012 at 22:14
swiftyboi006
So 15mm hubcentric spacers eill be fine?
Black p3 Love
Posted 14th Dec 2012 at 22:16
simonjames
but i doubt a 15mm would be enough to pass the 306 hub ??
MY EBAY ITEMS
07943066306
Posted 14th Dec 2012 at 22:17
swiftyboi006
?? So my next question would be....where do i get them? And what wheel bolts do i need?
Black p3 Love
Posted 14th Dec 2012 at 22:20
simonjames
bolts would need to be longer buy the thickness of the spacer IE for 20mm a bolt 20mm longer would be needed
MY EBAY ITEMS
07943066306
Posted 14th Dec 2012 at 22:30
swiftyboi006
Tapered?
Black p3 Love
Posted 14th Dec 2012 at 22:34
simonjames
if the wheel your fitting has a tapered seat then yes, it all depends on whats on the wheel
MY EBAY ITEMS
07943066306
Posted 14th Dec 2012 at 22:36
swiftyboi006
Cheers 4 the help. So hubcentric or lugcentric spacers?
Black p3 Love
Posted 14th Dec 2012 at 23:00
simonjames
i'd use hub-centric myself all you have to check is that the spacer sits on the hub with no up/down or sid/side movement and the same when fitted to the wheel, that way all the bolts are doing is tightening the wheel on if there is a loose fit when you hit a pot hole you risk breaking a bolt, i have only seen this once and that was on a BMW Z3 the guy had bad fitting 25mm spacers and a 9" width wheel and imo the threads were too short but i got a trip to Dover with his car on the back of my lorry Smile
MY EBAY ITEMS
07943066306
Posted 15th Dec 2012 at 11:16
