Author Subject: Hard Peddle
eddy_gti6
I have just fitted some wilwood midilites and a gti6 master cylinder with fresh ATE super blue racing fluid.
I drained all of the old fluid from thefront and back brake lines before changine the front calipers. Also fitted new braded lines along with the calipers and bled the full system going from offside rear to near side rear to offside front and nearside front. Then went round again to double check i got all the air out.
Fitted the wheels and took it for a drive and the peddle is rock hard.
Basicley when you have your engine turned off and pump the peddle it goes hard, then when you start the car it goes soft again. Well mine didnt, its still hard.
There are no fluid leaks from the pipes or joints, vaccume pipe is still conected to the servo too.
Any ideas?
Posted 16th Dec 2012 at 18:30
mr swampy s16
**BAD SELLER**
Sounds like a servo issue
Posted 16th Dec 2012 at 18:35
24seven
Have you got the valve in the vacuum hose the wrong way round?
Posted 16th Dec 2012 at 18:36
eddy_gti6
Av not took the vacuum hose off. Also my servo was fine thismorning before i changed my brakes and master cylinder.
May try putting the xsi Master cylinder back on
Posted 16th Dec 2012 at 18:42
simonjames
have you disturbed the vacuum ?
MY EBAY ITEMS
07943066306
Posted 16th Dec 2012 at 19:19
Might go away after a bit.
I had the same after new fluid and pads from a garage but after about 3 trios it sorted itself out :/
Not very scientific obviously
Posted 16th Dec 2012 at 19:21
eddy_gti6
Didnt touch the vacuum but i will give it a once over in the morning to see.
Posted 16th Dec 2012 at 20:12
tvrfan007
What size are the wilwood pistons? I take it fluid appeared everywhere during the bleeding sequence?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 17th Dec 2012 at 04:37
Hard pedal but the brakes are working/biting well?Dunno
Posted 17th Dec 2012 at 09:49
eddy_gti6
Yes there was fluid in every caliper and on the 2nd run around there was no air in the system, just fluid.
Yes they are working but not as well as they should, i have to put some force into the peddle
Posted 17th Dec 2012 at 09:53
jorg
If you swopped the master cylinder you could try adjusting the rod in the servo.
306 2.1 S16 Tarmac Rally Car
Posted 17th Dec 2012 at 10:03
eddy_gti6
How do you do that?
Posted 17th Dec 2012 at 10:35
jorg
I had a similair issue when I swopped the calipers and master cylinder on the 205 I had. Have a look at the link below:
http://forum.205gtidrivers.com/index.php?showtopic=78005
Posted 17th Dec 2012 at 10:40
i put a gti6 mc on my 205 servo. can't see why people on the 205 site don't use it, but nevertheless it wouldn't fit into the servo anyway due to the rod travel. wound it back in about 2mm and it fitted fine then. not sure on pedal travel though yet as there's no lines on the car but see no reason why i can't get it to work effectively by adjusting the rod. surely it just means i'd just be on max pedal travel a bit earlier?
*pedal btw Razz
Posted 17th Dec 2012 at 10:46
