displaying posts 651 to 675 of 741
Pages (30): first .. 26 [27] 28 .. last
Author Subject: S16Turbo, Here we go again!
Takedown
Post #651
Hey mate, i can pm you my number if you like,im not going in the 6 though
I dont know what the plans are since im with three more other people
Thx for the compliments guys
Posted 1st Aug 2013 at 17:11
Takedown
Post #652
Another one with Marv taking it easy.....
https://www.youtube.com/watch?v=MTZKx7G_nY8
gearbox is perfect , 3,4 and 5 from HDI, 3rd gear is very very nice!
Posted 1st Aug 2013 at 20:45
JWP EFi
Turbo Legend!
Post #653
congratulations mate, pleased to see it running, 350bhp is certainly not a bad figure.
Posted 1st Aug 2013 at 20:47
Takedown
Post #654
Yesterday it peaked @ 0.7 bar, so it should be around 370 then, puts the power down very good, but as said before the clutchproblems take a lot of driving pleasure away, but for now ill have to deal with it.
Going to fix the speedocluster after the weekend and then ill make some gopro vids for you guys from inside the car.
Posted 1st Aug 2013 at 20:54
JWP EFi
Turbo Legend!
Post #655
what sort of rpm do you start feeling boost?
Posted 1st Aug 2013 at 20:58
Takedown
Post #656
Thing spools quite quick, around 3000 it starts making big steps... around 4000 all hell breaks loose Wink and the screamerpipe Wink
Posted 1st Aug 2013 at 21:34
marco gti6
Post #657
f**king nuts says it all i think Crazy
Posted 1st Aug 2013 at 21:37
JWP EFi
Turbo Legend!
Post #658
3000rpm that seems responsive. do you notice the boost wanting to tail off or are you still making good pressure at redline? I'm assuming so seeing as your only at ~10psi
Posted 1st Aug 2013 at 21:38
Takedown
Post #659
Hahaha its a GT3071R , that thing hasnt even started to do any serious work yet on 0.6 bar Wink
Posted 1st Aug 2013 at 21:58
Takedown
Post #660
I moneyshifted the 6 today... i think a valve hit the piston :S
Kaput!
Posted 2nd Aug 2013 at 17:06
heliosphan
Post #661
Takedown wrote:
moneyshifted
Remortgaged?
Posted 2nd Aug 2013 at 17:31
Takedown
Post #662
google -> moneyshift
Posted 2nd Aug 2013 at 20:55
eddy_gti6
Post #663
Think i liked the 1.2s on there better. Good work
Posted 2nd Aug 2013 at 22:15
Post #664
We're not american. Over here it's called a 'f**kup' Thumbs up LOL
Posted 2nd Aug 2013 at 22:18
Takedown
Post #665
hahah Phillip, BIG f**kUP IT IS THEN Wink
Posted 2nd Aug 2013 at 22:22
mike rallye
Post #666
Very nice result and sound great in the video to.
Posted 2nd Aug 2013 at 22:38
cescnathan
Post #667
wow...,very nice job.....I want one Thumbs up
Posted 3rd Aug 2013 at 04:53
marco gti6
Post #668
The wheels look the Rita, specially with those huge calipers behind them.
What males you think you f**ked one of the valves? That souls be a bloody shame. Pm me your phone number and let me know what time you guys will be here so I can see if I can make it time wise.
Heads up and cheers Paul Thumbs up
Posted 3rd Aug 2013 at 09:50
marco gti6
Post #669
Bloody autocorrect Angry
Posted 3rd Aug 2013 at 10:47
Takedown
Post #670
marco, we left at 06:00 since its a 4:30 drive for us, so i didnt read your reply mate....
Had a nice day at the Ring...
and you?
Posted 3rd Aug 2013 at 21:46
JWP EFi
Turbo Legend!
Post #671
TD - if your pistons have been machined to give you an 8:1 compression ratio then i doubt you've had valve to piston contact. IIRC your modified pistons will be 4mm below deck.
Posted 3rd Aug 2013 at 21:58
Takedown
Post #672
were going to have a closer look @ the engine in the upcoming week, ill update when we know more!
Posted 3rd Aug 2013 at 22:18
marco gti6
Post #673
To bad I could not make it my ge had some family that came to Luxembourg on vacation so we went to a good restaurant with them. I'll be on Aalten, Gelderland at the end of August. Aren't you from around there?
Posted 3rd Aug 2013 at 22:20
Takedown
Post #674
No problem Marco..
Well i layed out the carpet, pushed the old shed into the barn and got to work.
Dropped the oilpan
Removed the rodcaps, and removed the bearings, they were not in the best of shape, and cyl 3 was the worst..
When we replaced the steel oilpan for the alloy one, the alloypan almost didnt fit, pickup of the oilpump was kinda touching the pan.
I thought this wouldnt be a big problem, since i tested oilpressure afterwards and it was fine, the problem i had with driving the car after mapping ( didnt drove it much) was that my oiltemp was on the highside 100+ even on normal driving, oilpressure was good!
Good oilpressure doesnt mean theres enough flow though, and we thing this is what caused this, high revving of the engine with not enough flow (starvation)
Since i overrevved it full power in 4rd, the bearing decided it had enough, hence the tapping straight after the overrev
The crank looks very good, only where rod 3 is there are some light scratches to be seen, i cant feel them.
Were going to order 8 new bearings, put in the old sump (since i dont want to change back to the smaller oilpump for now)
Going to install the new bearings hopefully this week and then well have to see what happens Wink
It should hold for a while, hopefully until end of september then the car is back in
its place in the barn and were starting the build of the forged engine.
I then also need to buy a new clutch, were pretty sure that this clutch is fked hence the problems.
Will update asap
Cheers!
Posted 4th Aug 2013 at 18:47
dcc
Post #675
My nan just phone me. She said that even she can see those shells are basically f**ked, and she's blind. Drop that crank out, source a new one to retain the standard sized bearings. Or just get yours out and machined (or polish if you get away with it).
205 GTI
Xsara HDI
Posted 4th Aug 2013 at 18:50
This thread has been locked
