Author Subject: Rpm limit
tarret
Hi does anyone know what rpm limit standard internals are good for before having to change bolts, rods, crank Etc
Posted 25th Dec 2012 at 11:33
Depends how long you run them at max rpm for as stress is cumulative. 7,400 probably fine all day long, 8,000 probably 500-1000 miles of hard use with better rod bolts, 9,000 probably all of ten seconds without forged rods and pistons. Not a lot to be gained by increasing the rpm on standard cams though as torque drops off rapidly past 6,500.
Posted 25th Dec 2012 at 11:37
tarret
I'm currently revin to 7200rpm in my s16 with kent cams, bike bodies and remap, bhp and torque figures are constant all the way, but due to it being quite high millage now :/ its due a rebuild and was curious on what the internals are capible of so I know if to uprate them or not,
Cheers davey
Posted 25th Dec 2012 at 11:52
shouldn’t need to rev it much further at all, check the cam timing, having it retarded will push peak power up the rpm and drop torque.
its the valvetrain that limits things in the main.
Posted 25th Dec 2012 at 12:10
aaron6
Your engines alright dean. It don't smoke or make dodgey noises. I'd say just raise it a tad if need be but I reckon once you map it you'll probably not need too. Wink
Posted 25th Dec 2012 at 12:19
tarret
Does smoke under load and smokes out of the dipstick :/ and having 104psi in cylinder 3 can't be good lol
Posted 25th Dec 2012 at 12:29
err, yeah, should be double that Hmm
Posted 25th Dec 2012 at 12:45
tarret
Yeah that's what I was thinkin, it's got no low down power till atleast 4200rpm, which is depressing
Posted 25th Dec 2012 at 12:47
well sort the compression when whilst putting it back together sort the cam timing Thumbs up
Posted 25th Dec 2012 at 12:57
tarret
Cam timing was done when I had it remapped, but defo need to sort the compression out asap
Posted 25th Dec 2012 at 12:58
