Author Subject: 300mm discs
JWP EFi
Turbo Legend!
will 300mm discs fit inside the 406 brembo caliper in its standard position?
after the new year i will be getting a set of Mk1 focus ST discs machined out so they will fit onto the 306 hubs
reason for me doing this is so that i can put my cyclones on with just a 5mm spacer,i already have 1.2's and a set
of speedlines that clear the current 288/brembo setup but i would like to still be able to fit the clones just not with
20mm spacers lol.
According to my measurements the ford discs will clear bottom balljoint by approx 4mm
Posted 30th Dec 2012 at 17:36
standard position on a 406 hub, hell yeah, they used 305mm, the closer to the hub position on a 306 hub, no, 288mm required.
Posted 30th Dec 2012 at 17:41
Rich E Forum Admin
There are some photos here showing clearance on 283 and 288 discs:
http://www.306gti6.com/forum/showthread.php?id=95186
Posted 30th Dec 2012 at 17:42
JWP EFi
Turbo Legend!
ok, cheers guys. Looks like i'll have to reduce the diameter of them as well
Posted 30th Dec 2012 at 17:47
