Author Subject: driveshaft causing vibrations?
darkgti6
Could a knackered cv joint cause vibrations which feel like unbalanced front wheels? Getting vibrating at motorway speeds. Ive been getting a few clonks and clicks from the offside shaft. Only really when I instigate it by going full lock right on a hill, pulling away and allowing the car to then stop and roll backwards. Getting some awkward sounding clonk and click everytime?
Team Peugeot Sport 308 Gti�
Posted 13th Jan 2013 at 14:01
It could either be that or the halfway bearing on the offside shaft faulty...
Posted 13th Jan 2013 at 14:48
swiftyboi006
Could be a couple things together id just get the car up and have a look youself before anything. Check the wheel for movement, then take it off and inspect everything. Check the balancing weights are still on the wheel then go over everything. Check the ball joints, driveshaft, bushes everything. Even check for excessive engine movement. I had almost exactly this with the clunking and it turned out to be the top engine mount
Black p3 Love
Posted 13th Jan 2013 at 22:19
beez_neez_gt
I think we have this on the 106, the steering wobble isnt the same as unblanced wheels its more of a subtle wobble. Going around 50 mph and i can hear the driveshaft make noises but not below that speed.
I think it is the driveshaft on yours, i checked mine and movement is there at the hub side of the driveshaft.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 13th Jan 2013 at 22:43
monty-69
On diesels i have seen the spring fail in the offside driveshaft inner joint
Posted 14th Jan 2013 at 13:52
rich306
Recently travelling in a transit van, the Driveshaft gaiter had gone on it causing the Grease to flick everywhere inside the wheel arch, Thus causing the vibrations.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 14th Jan 2013 at 19:25
Yes, once the grease has been thrown out of the joint the joint will run dry and wear at a very fast rate causing vibrations and then failure.
Posted 14th Jan 2013 at 20:42
beez_neez_gt
What happen when it fails so i know what to watch out for lol.
Pug fee`ver,
Posted 14th Jan 2013 at 20:49
There is usually a loud bang and then the car won't drive anywhere. You can have it in gear and let the clutch out and the car will just sit there...
Posted 14th Jan 2013 at 21:18
beez_neez_gt
Yeh i thought as much just didnt expect a large bang too.
Pug fee`ver,
Posted 14th Jan 2013 at 21:48
beez_neez_gt
Pug fee`ver,
Posted 14th Jan 2013 at 21:49
worst case is the broken bit flails about taking out a brake line.
Posted 14th Jan 2013 at 21:58
Nothing like cheering you up...LOL Thumbs up
Posted 15th Jan 2013 at 10:51
