| Author | Subject: can a 205 gti 1.6 box go in a gti 6? |
stevec33
Newbie Location: Peterborough Registered: 18 Jan 2013 Posts: 41 Status: Offline |
as title ive got a gti 6 track car and the synchro is getting weak on second gear, i had a 205 gti 1.9 with the 1.6 box a while back and it flew due to the lower ratio's. Was wondering if the same can be done with the gti 6 easily and if its worthwhile or not. Any advice appreciated, cheers |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
main problem is the Ns drive shaft cup and clutch linkage. Xsara vts is the way to go for 5 speed |
The box fits but I'm not sure the shaft will ? Also you need to change the clutch and flywheel I believe ? |
Put the 306 diff in it - no shaft problems then.________________________________________ ![]() |
no shaft problems anyway, its the other way round you get issues.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stevec33
ok thanks for the replys, are the ratios lower/different in the xsara box to the gti 6? like i said would be great to get some more acceleration out of it if a lower ratio box is a straightforward swap |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
Not sure what the ratios are but I imagine 1-5 of the GTi-6 box are similar to the 205 1.6 box.________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
scotzman wrote: Not sure what the ratios are but I imagine 1-5 of the GTi-6 box are similar to the 205 1.6 box. Look them up. You'll be surprised. ________________________________________ ![]() |
scotzman
just did ![]() http://www.205gti.com/techgearboxUK.htm ________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
yup, you're in the right ballpark there with that comment, but 4-5-6 are closer.gear speeds @ 7200 rpm on a 4.05 FD for the gti6 box. 41 64 85 104 126 150 gear speeds @ 7200 rpm on 1.6 box (4.06 FD, 3.3 of 2.92 1st) 36/41 64 88 112 138 all on 195 50 15. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
allsmiles
Regular Location: burton upon trent Registered: 07 Sep 2009 Posts: 320 Status: Offline |
i ran a 1.6 gti box on a gti6 engine and that those gears were really close, possibly a bit too closethe xsara box would be the way forward i still have a 1.6 gti box(be1) in my shed that i kept for spares ________________________________________ 205 gti6 now sold up, but gonna stick around and see whats what |
stevec33
The thing is i dont mind them quite close as its only going to need to top out at say 120mph really as its a track only car, no point having a box with gearing for say 160mph as your just wasting acceleration. Dosent look to me as though the ratios on paper are that much different 1-5 between the two though? Would the xsara box give me better acceleration? Not really heard of doing that conversion as you'd expect the ratios to be longer with it only being 5 speed |
allsmiles wrote: i ran a 1.6 gti box on a gti6 engine and that those gears were really close, possibly a bit too close funny quote, given 1-3 are nigh on identical, and 4-5-6 are closer together ![]() MI16/zx16v ratios @7200 on 195 50 15. 38 59 86 113 144 vts ratios 38 59 86 115 148 ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stevec33
Anybody got any comments on the xsara box then? |
