I understand it could be the p bushes, droplink, top mount. In which order would I start checking/replacing these as to not spend more money on un-needed parts?
| Author | Subject: In what order would you check suspension knocks? |
DanRM
Regular Location: Birmingham Registered: 18 Jan 2013 Posts: 120 Status: Offline |
When I bought my 6 last week I was told that the ball joint needed replacing as theres a knock on the n/s front, he had the part already so I put it on along with doing the brakes. Put it all back together and the knocks still there. I've only noticed it going over rough roads and worse over pot holes.I understand it could be the p bushes, droplink, top mount. In which order would I start checking/replacing these as to not spend more money on un-needed parts? Cheers |
rikky
checked for play in the wheel first of all?? at 12 and 6 and also 3 and 9? ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
Don't forget to check the above at twenty to 2 and and 10 past 8 ________________________________________ ![]() |
jord294
Worn drop link maybe???________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
stan_306gti6
Drop link if it makes a kind of "boing" noise. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
DanRM
Ok i'll change the drop link first then. Would any of those cause a vibration/shaking right down the side of the car when doing about 60 or above? The suspension has been lowered a lot ( I do plan on raising it again) if that makes a difference |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
drop link and wheel balancing.visually check the p bushes for wear/splits |
gilesy
Seasoned Pro Location: Greenwich - in that London Registered: 03 Apr 2006 Posts: 5,133 Status: Offline |
rikky wrote: checked for play in the wheel first of all?? at 12 and 6 and also 3 and 9? I checked it at 0645 and 1023, also at 1117 but everything was the same? |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Lol.________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
