displaying posts 26 to 50 of 51
Pages (3): 1 [2] 3
Author Subject: help headgasket question + cams
Teshboi1988
right i measured my head. 3 to 4 times.
according to my digital vernier. the height of the head not including the cam covers. the height is 137.1
little bit baffled lol
phase 3 Hatchback V reg 5Door GTi6
Posted 10th Feb 2013 at 09:26
Are both the cam carrier faces and the head gasket face perfectly clean and free of previous gasket/debris?
Posted 10th Feb 2013 at 10:21
Teshboi1988
yea completely clean mate
Posted 10th Feb 2013 at 11:30
Perhaps try another set of verniers to compare, yours may need calibrating? Best to rule them out. Yes
Posted 10th Feb 2013 at 14:10
Surely its just a standard height head?Dunno
You know for sure it was skimmed? ? Could be someone tell porkies to sell it on....
Posted 10th Feb 2013 at 14:14
There is always that too...what makes you so sure it has been skimmed?
Posted 10th Feb 2013 at 14:18
bas_306gti
here a picture of a head who has been skimmed one time:
Posted 10th Feb 2013 at 15:07
Teshboi1988
yea definitely been skimmed, those notches u guys were referring to. mine are barely visible.... il see if i can get it re calibrated and try again n let you no
Posted 11th Feb 2013 at 07:25
Ok, keep us informed of progress. Thumbs up
Posted 11th Feb 2013 at 07:56
Teshboi1988
Post #35
had it calibrated and the hieght of my head is
136.71mm
recommended headgasket thickness???
Posted 13th Feb 2013 at 07:36
Post #36
Fattest you can find LOL
Posted 13th Feb 2013 at 07:40
Post #37
Agreed. LOL
Posted 13th Feb 2013 at 07:46
Teshboi1988
Post #38
1.55mm??
Posted 13th Feb 2013 at 08:19
Post #39
That's certainly a good starting point. To be fair, the head height minimum is 136.8mm +/- 0.05mm.
Therefore at your figure of 136.71mm, you are 0.04mm outside of the maximum tolerance permissible. It will be touch and go whether or not that head is reusable really. Sad
Posted 13th Feb 2013 at 10:01
Post #40
std repair gasket is 1.4, if you find a 1.45 you'll be reet.
Posted 13th Feb 2013 at 10:23
milkyb
Post #41
136.71mm
am i the only one that found this funny?
Posted 13th Feb 2013 at 10:33
lost4words
Post #42
no i chuckled out loud in the office and got strange looks
Team 'No Longer A 306 Owner'
Team 'VTEC'
Black Honda Civic 'EP3' Type R
Moonstone 306 Gti-6 - Died at 82k
Black 306 HDI - Sold 08/08/2010 at 102,229
Posted 13th Feb 2013 at 10:46
milkyb
Post #43
you COL'd?
Posted 13th Feb 2013 at 10:49
Teshboi1988
Post #44
Lol funny stuff. Anway
1.55 ok or thicker need prefernce please. Wot wood u do stan
Posted 13th Feb 2013 at 13:48
Post #45
A gasket 1.45mm thick will take it back to 136.96mm, so will be ok with this. Yes
Posted 13th Feb 2013 at 14:50
Post #46
as above, will be within tolerance then Smile
Posted 13th Feb 2013 at 14:59
Post #47
Unfortunately, it will be a fibre gasket as Welshpug said, which whilst they are perfectly fine to use I just have a pet hate from them and much prefer the MLS design.
However, saying that, in this instance you've got no choice. Smile
Posted 13th Feb 2013 at 18:58
Teshboi1988
Post #48
ok cool il see what i can find...
sp what would happen if you went over tolerance.
say i put a 1.55mm gasket on and it was over 137?
Posted 14th Feb 2013 at 07:30
Post #49
You'd be slightly down on standard compression. Wink
Posted 14th Feb 2013 at 07:50
Teshboi1988
Post #50
pug 1 off can get any size head gasket multi-layered steel. ordered.
if i get a bottom pulley (alloy) do u know if there is a rubber or solid?
isit worth getting one to ensure timing
Posted 15th Feb 2013 at 07:50
Pages (3): 1 [2] 3
