Is this repairable or is a new part needed?
Thanks for any advice,
Tom
| Author | Subject: Cracked cat |
tomlum
Regular Location: Lincoln Registered: 17 May 2011 Posts: 210 Status: Offline |
Hi all, thought my car was getting louder then did a 6 hour trip over the weekend and it suddenly got louder and deffinatly blowing somewhere. Jacked it up to find this..![]() Is this repairable or is a new part needed? Thanks for any advice, Tom |
Can be welded easily________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
As Kev said it can be welded but dependant on how bad the crack is how thin the metal is it may not last that longI've got a cat if you wanted a replacement |
I'd weld in a new bit of pipe to the old flange/cat myself, but yes as said, easy enough to fix. Problem with a second hand cat is it could go exactly the same within weeks or months of fitting as they fail without warning.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
If your car passed the MOT emmisions easily last time get it off and get it repairedIf it was a close call to get through the test it's prob time to buy a new cat ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
If the budget is tight: http://www.306gti6.com/forum/showthread.php?id=153030 ________________________________________ ![]() |
tomlum
Thanks for the advice guys! Been to my local garage this morning and they have had a look. They recommended getting a new cat and just fitting that as there pretty cheap now and the weld may only be tempory fix! Is it easy to bolt off and bolt new one in? |
tomlum wrote: Thanks for the advice guys! Been to my local garage this morning and they have had a look. They recommended getting a new cat and just fitting that as there pretty cheap now and the weld may only be tempory fix! Is it easy to bolt off and bolt new one in? If its welded properly (at a garage it wil almost certainly not be properly welded, sorry but it's true, most garages suck at welding) then it won't be a temporary fix. If the just blob up the corroded bit of pipe then it wil certainly fail in a short time. A new pipe section would be thicker and longer lasting than the original. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
New cats are cheap, the ones with a 12 month warranty!!! And the fit on some are shocking.The garage would say fit new, cause as above they are not good enough to repair it properly ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
tomlum
Got it welded today, nice a quiet once again see how long it lasts! |
swiftyboi006
By a garage? if its done properly it will be just as good as a new 1.________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
