Author Subject: Braided brake hose
jamiek_uk2000
From what point of the rear brake line would a new braided line run from, is it from the flexi that runs under the rear beam or do the braided lines replace that flexi aswell?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 16th Feb 2013 at 00:14
Its literally just the rubber flexis you would get from eurocarparts or whatever that get replaced usually.
If that makes sense
Posted 16th Feb 2013 at 00:16
jamiek_uk2000
So there would be the solid line that then runs from the flexi to the caliper as normal?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 16th Feb 2013 at 00:17
Yup, anything existing that's rubber gets replaced, so the solid lines go straight to your new flexis. The only bit of flex at the back goes between the chassis and the trailing arms:
Rears:
Fronts:
Posted 16th Feb 2013 at 06:39
jamiek_uk2000
The fronts are only like that on yours due to the Brembo's though? Normal front hoses go straight into the caliper. I suppose I better order some new rear lines then, I may have damaged the original one slightly Whistle
They are bent back holding the system full of fluid
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 16th Feb 2013 at 07:14
mr swampy s16
**BAD SELLER**
The only cars that had a flexi line to the rear caliper are the s16 and very early xsi, but that design was soon changed to a solid pipe along the trailing arm and just a flexi around the beam.
Posted 16th Feb 2013 at 07:26
jamiek_uk2000
That would be what I saw fitted then, I was wondering how they converted from the type fitted to my car, anyone know how much those two rear hoses that run from the rear flexi to the caliper...
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 16th Feb 2013 at 07:28
You dont need them, just mwke the hardline longer.
Posted 16th Feb 2013 at 07:33
mr swampy s16
**BAD SELLER**
thats what fe is on about!!!
Any local factors should be able to make you them up probs less than a fiver a line.
Posted 16th Feb 2013 at 07:47
