Author Subject: heater
dazzy6
Heater only works on number 4 in my rallye but nothing comes out of the vents . Hope the matrix hasnt goneAngry .any ideas ?
darrenevans
bianca white rallye t706wox
Posted 21st Feb 2013 at 13:34
Yeah, check it over Yes
Are the pipes connected, are the cables attached to the knobs, does the blower fan work if you give it 12v directly etc.
Posted 21st Feb 2013 at 14:24
jimmyhackers
try bleeding your heater matrix with the little thumb screw in your engine bay where the pipe goes through the firewall.
basically with you engine running, open it untill water comes out, then close. if water came out straight away your matrix didnt need bleeding and this wasnt the problem.
other than that do as mentioned above, check for loose wires and wayward connections
Posted 21st Feb 2013 at 15:16
