Author Subject: Peugeot sport ml6 6speed with the big Peugeot sport drive shafts
Maxi rally
Apparently peugeot sport made a close ratio ml6 6 speed, Does anyone know if there are any of these left in existence? Broken ones considered for spare parts.
Russ
Posted 25th Feb 2013 at 10:58
got any pics of yours? wondering if its based on the factory ML gearbox or not, as the ML6C factory gearbox wasn't used till the very late 90's at the earliest.
I do know they did a BE3 6 speed dog unit for the 309 and saxo/106 which was inside a 5 speed casing, sadev used to sell them too.
Posted 25th Feb 2013 at 17:08
Maxi rally
Yes , will post pics, but is a ml6c with the cable change and the oil filler off the diff housing.
Posted 25th Feb 2013 at 19:41
Do you know of any limited slip diffs for the ML boxes? Quaife did one for a bit (standard on some Boxer vans) but its not available unless you buy 10 at £1200+ each.
Such a shame they didn't stick one in the V6 manual coupe and get rid of some of the restrictrions...
Posted 25th Feb 2013 at 20:19
JWP EFi
Turbo Legend!
^^^what, boxers have lsd's??
Posted 26th Feb 2013 at 07:26
No
But people use the ML box in cars and want to fit an LSD, unfortunately Quaife list such a product but wont tool up to make it in quantities of less than 10.
Posted 26th Feb 2013 at 08:54
Some were listed as having them yes. However there is no record on the Peugeot system as to when and where they were fitted.
Probably an optional extra in Scandinavian countries - one guy on the 406 coupe club has one, no one has found any others.
Posted 26th Feb 2013 at 10:22
well 3 or 4 others others want them
If i was you lot i would get quaiffe on the blower and see if they would do five at a persumably inflated price or say 1000 each.
Posted 26th Feb 2013 at 12:46
Well they want £1200+ each for 10... Tbh it'd be cheaper to buy a better car. Its nearly twice what the car cost originally!
Posted 26th Feb 2013 at 13:24
Ah right sorry i missed that bit.
Yeah, depends how much you want the car really, Its worths it if say you had a High boost with a ML gearbox imo.
Posted 26th Feb 2013 at 13:32
I'm sure sadev would have something, as their box on the c2's used an ml spline...
Posted 26th Feb 2013 at 14:40
birk
Be great if you could find something, I will be using an ml5 box.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 26th Feb 2013 at 19:26
For the faff anyway would a Clio v6 box work out cheaper?
Posted 27th Feb 2013 at 00:18
Probably wouldnt be that much work making it fit, goes on the engine which us the hard part.
Posted 27th Feb 2013 at 06:42
