Author Subject: pas relocation
JWP EFi
Turbo Legend!
whats involved/needed to move pas pump down where air con compressor normally lives?
looking at a nice intercooler and want to run boost pipe under the inlet manifold
Posted 26th Feb 2013 at 08:49
A relocation bracket and associated plumbing from Rich_W is normally the way to go.
Posted 26th Feb 2013 at 08:53
JWP EFi
Turbo Legend!
ok. is he still doing the relocate kit?
Posted 26th Feb 2013 at 09:05
He still does the lot as far as I'm aware, try PMing him Thumbs up
Posted 26th Feb 2013 at 09:24
smegal
As above. Rich_W, Carl or even spoox will do them.
Ex SC-6
Now in a Megane R26
Posted 26th Feb 2013 at 15:02
S16 or 8v xsi non aircon setup, lighter than setups mentioned and cheaper.
Posted 26th Feb 2013 at 16:29
So on a S16 the PAS pump is where the AC is on a GTi-6??
Posted 26th Feb 2013 at 16:48
if its a non ac S16 yes.
Posted 26th Feb 2013 at 16:49
Lighter you say, I assume its usefully so?
I always enjoy i lighter option if possible. I assume this wouldnt prevent you running a sc kit for whatever reason if you decided to go for the s16 option rather than the pas relocation kit that comes with he charger?
Posted 26th Feb 2013 at 17:30
You wouldn't be able to use it with a Lynx/Rotrex SC bracket bracket, its significantly smaller.
Posted 26th Feb 2013 at 17:45
JWP EFi
Turbo Legend!
welshpug - could i use the above but the ph1 8v xsi version? and could i reuse my GTI6 alternator,
pas pump and crank pulley?, iirc using the 6 pulley with all those bits doesn't allow the belt to run
true
Posted 26th Feb 2013 at 20:29
JWP EFi
Turbo Legend!
true
...ive just had a think about this and answered my own question lol - pas pump pulley wont be in line with crank pulley
think alternator will have same problem
so i'm gonna need S16 bracket or 8v XSi (if its the same), alternator and pas pump plus tensioner and pipework
alterations
Posted 26th Feb 2013 at 21:25
crank pulley lines up just fine.
Posted 26th Feb 2013 at 21:27
JWP EFi
Turbo Legend!
Mei - have you still got spare S16 kicking about?
Posted 26th Feb 2013 at 21:38
yup
Posted 26th Feb 2013 at 21:40
vts_tibi
Can't we fit the GTI6 alternator and PAS pump using the S16 bracket? Could cost a fortune buying an alternator and a pump from the scrappy here...
VTS
best 60' : 2.272
Team Trackday™
Posted 26th Feb 2013 at 21:46
JWP EFi
Turbo Legend!
yup
does it have the bracket i need?Wink
Vts - i'm pretty sure the mountings are diffrent plus the pulley offsets are different
Posted 26th Feb 2013 at 21:54
pulley offsets are the same, however the alternator brackets are different, your best bet is to get the complete setup, however I;m sure the gti6 pump could be used.
I'm not sure yet what I'm doing with the ancillaries, but the engine is up for grabs.
Posted 26th Feb 2013 at 22:05
JWP EFi
Turbo Legend!
my work mate is looking for an S16, only really needs head and couple other bits but would be happy
to buy a bare engine, ie, no manifolds. How much you after? Pm'd you a wee while ago but no reply
Posted 26th Feb 2013 at 22:11
miles
The Alt is different, the S16 bracket hit's the Alloy sump as the S16 engine's had a Tin sump (Without AC) PAS pump will fit either thou but I would not use the S16 pump as the pulley is too large
www.pugracing.com
Posted 26th Feb 2013 at 22:57
JWP EFi
Turbo Legend!
looks like its gonna have to be a richw kit or just do away with the power steering, as i had my ally sump
fitted with an oil drain fitting
Posted 27th Feb 2013 at 07:42
easy fix
Posted 27th Feb 2013 at 08:37
JWP EFi
Turbo Legend!
mei, as in cut off air con pump lugs on sump?
Posted 27th Feb 2013 at 09:22
