Author Subject: piper cams?
inzomatic
hello again was wondering what the advantage of having piper cams fitted to my 6 is? im pretty new to this and trying to gain an insight and some info on my pug which i havent had for long so apologies for being cluelessThumbs up
Innes drummond
Posted 4th Mar 2013 at 21:37
ed_doe
Depending on your application, cams can provide different lift and 'duration', that is how far the valves open, and how long they open for. Most ordinary cars have cams set up to allow decent midrange torque often at the expense of high end power. The compromise on an n/a engine is that when you cam it, unless you really know what you're doing and spend a fair old bit, you invariably end up pushing the power band way up the Rev band, and sacrificing a lot of the low end and midrange torque inthe process. This on its own makes the car harder to drive daily unless you're always always interested in the right gear to keep the engine on the boil.
Essentially though a set of cams mild enough to fit in a stock engine will deliver probably 15hp more at the expense of a little midrange. But if properly mapped you probably won't notice the reduction in midrange...
'97 Black Dturbo 110,000miles: SOLD
'99 Ph3 Diablo Gti6 108k RIP
'93 106 1.5n/a d: daily hack YAAAAAWN
'00 Ph3 Astor GTi6 117k Love
Posted 4th Mar 2013 at 21:44
And I have a nice set going fairly cheap Whistle
Posted 4th Mar 2013 at 21:51
ed_doe
Haha in with the self plug LOL
Posted 4th Mar 2013 at 22:01
inzomatic
thanks for the info will be gradually asking questions as i go recently had my cylinder head looked at got new head gasket head set and bolts ,new timing belt water pump etc also had head pressure tested and apparently a lot of repairs were done ......HOWEVER noticed when i got it back it was running ruff and could here a tapping got a compression test from a fellow pug driver who is on this forum and found cylinder 3 was at 160 psi with the others being at 220,240 was suggested maybe bent valves although when ive been driving it recently it drives great although still taps i think? i dont have anything to compare it to so dnt know if i should just leave it or is this likely to bite me when i least expect it?
Innes drummond
Posted 4th Mar 2013 at 23:05
That's definitely something I'd want to investigate further, compression figures should really be within 10% of eachother.
Posted 4th Mar 2013 at 23:27
JWP EFi
Turbo Legend!
It may run like this for a long time but theres a change it will drop a valve which WILL lead to a totally destroyed engine
the tapping noise i heard plus the lack of compression certainly means a bent valve or two, they garage who did
the job have either cocked the timing up or have accidently bent the valves when they refitted the head. Its a fairly
heavy assembly, plus these engines are tilted back by 30 degrees, so easy to damage
Posted 4th Mar 2013 at 23:37
inzomatic
do you still have a reconditioned head for sale seb? because if i sorn my pug also known as "EL GUAPO" id still like to see it through to a finished item
Innes drummond
Posted 5th Mar 2013 at 00:02
Yep, sounds like the garage bent a couple of valves when refitting the head, easily done. Sad
Posted 5th Mar 2013 at 06:21
inzomatic
how expensive is it to fix?
Innes drummond
Posted 5th Mar 2013 at 07:00
JWP EFi
Turbo Legend!
assuming its not been a previous snapper and assuming the valve guides are not damaged then its the cost of another new head gasket and set of bolts, new belt-i'm not keen to retension/reuse a timing belt plus new valves then labour on top.
yes i still have a reconditioned head
Posted 5th Mar 2013 at 07:52
inzomatic
how much for the head seb ? seen one on e bay for £100 but dont know if i would trust it
Innes drummond
Posted 5th Mar 2013 at 08:52
If you are asking someone to do it for you, it would probably be around a £500-600 bill for cylinder head removal, repair and refitting. Yes
Posted 5th Mar 2013 at 10:08
fixing yourself given its only just been apart, £10 a valve IIRC, plus £40 a gasket, £15 belt.
plus any valve seat cutting IF required, you can re-use the head bolts as long as they are within spec, as they are not stretch type and should have already been replaced.
Posted 5th Mar 2013 at 17:12
Yeah, if you feel confident to do the repair yourself, you could probably get it done for under £100. However, it's whether or not you feel able to undertake the work.
Posted 5th Mar 2013 at 19:03
inzomatic
not sure im a stonemason to trade so unless i can hit with a hamner dunno if i would manage would be really good to gain the knowledge of what is required even from joining this forum ive learned things particularly how to avoid being ripped off however i have learned the hard way !! first time ive had a gti so hopefully i can keep my pug alive
Innes drummond
Posted 5th Mar 2013 at 19:50
JWP EFi
Turbo Legend!
no offence mate, but to undertake a job like this on a 6 or any vehicle for that matter requires some
previous experience, its all a basic principal but unless you know what your doing then leave it to
someone who has relevant experience.
Posted 5th Mar 2013 at 21:06
inzomatic
aye am happy to do that if a plan is put in place ! i like to have a clear idea of how and when something will be done and from my recent dealings with garages ive found things arent always what they seem
Innes drummond
Posted 5th Mar 2013 at 21:27
Where exactly are you based? Dunno
Posted 5th Mar 2013 at 22:23
inzomatic
central scotland m8 near stirling
Innes drummond
Posted 5th Mar 2013 at 22:38
Ok, I would have perhaps taken a look for you if you were closer. Doh
Posted 6th Mar 2013 at 07:27
