Author Subject: ML6c Close ratio dog engagement box
Maxi rally
I have this box in my car. Its a Pug sport item and peugeot sport shafts.
I need to source some new drive shafts and spares. Does anyone know about them? Does the 207 RC rally car run the same box.
Ideally expert opinions required, rather than internet speculation.
Thanks Russell
Posted 5th Mar 2013 at 22:28
You wont find any expert opinions on here LOL seems anyone that knows about these cars does not use the internet.
Also if it was built in the UK it could be anything, totally unrelated spec to a proper pug sport france car.
Which part of the shafts do you need? outer or inner CV's?
Posted 5th Mar 2013 at 22:44
devere
Judging by one of your previous pictures and seeing the parts used in the suspension, eg the front anti roll bar, then it looks like you probably want to give Special Tuning a call. It looks like they are the same batch of parts that they supply here, rather than the French Peugeot Sport people.
Posted 5th Mar 2013 at 22:51
Can GKN help you out with the driveshafts? They are a big name in all things drive shaft related after all.
Posted 6th Mar 2013 at 00:15
Big name, big $$$$$$
Posted 6th Mar 2013 at 07:49
It's not as if parts from Peugeot Sport will be any cheaper is it? The guy has a 306 Maxi, he's obviously going to have to spend a few quid getting what he wants as he can't exactly nip into Euro Car Parts and get the required parts can he?
Posted 6th Mar 2013 at 08:21
Its not a maxi that you or i would imagine, its totally different.
Remember those btcc pugs that never amounted to much? Pug sport uk, french ones were a different world!!
Posted 6th Mar 2013 at 08:25
I know it's not a full spec Maxi, but obtaining anything gearbox related or specialist won't be cheap, whatever it is. Some of the GKN CV joints are pretty reasonable and you know for sure the quality will be there. With reliability bieng key to success in competiton I'd imagine he'll be wanting decent stuff anyway.
Posted 6th Mar 2013 at 08:41
given he's in oz I would inspect the shafts and ascertain what they are exactly, and get a local specialist to sort them out (personally I would take the same approach in the UK or on mainland europe)
For example, I know of a guy on the 106 RR in Ireland building up a maxi type 106 rally car, obtained a sadev box, checked out the cv details, found they were incidentally the same pattern as an ML box, got some 406 shafts and mated them to the cupcar outer cv's (totally different to proper kitcar/maxi stuff, as they used pawl drive very large twin bearing hubs as used by WRC cars, usually built from alloy plate.
ML inner CV -
maxi/wrc/kitcar type hubs.
without getting hold of the car's builder or taking it apart and inspecting the parts and posting pics, you wont get very far.
Posted 6th Mar 2013 at 09:16
http://www.pam-sport.com/doc._306_maxi_1042.htm
most of that probably not applicable though, as you aren't wide track, or french built.
Posted 6th Mar 2013 at 09:31
http://krs-competition.pagesperso-orange.fr/index.htm
there's more there too.
Posted 6th Mar 2013 at 09:34
pete_rallye
Not an expert but I think I have the same driveshafts as you... bigger splines but same size other than that? You can apparently still buy them from pugsport but are a tad expensive (£800 rings a bell). I've been told that the splines are the same fitment as mondeo driveshafts if that helps though...
Lap of the 'ring
Posted 6th Mar 2013 at 18:56
Maxi rally
Yes they are not cheap to run, we do most of the prep ourselves as this is now my 10th year of rallying. We do spend on preventative maintianance and tyres, we only run at a 'clubman' level but try to do higher level championship events , ironically faster but much safer.
Would not like to put a cost to it, but cheaper than the UK in terms of event costs - 150km competitive entry fee about 350 quid, but the event may cost more than 10 - 15 times that in fuel, tyres and wear and tear before breakages and other stuff (crew beer)
Usual story - motor racing is expensive. This is my 3rd professionally built car (I have had a factory built Diahatsu and Honda Civic prior) and I have to say the better and more expensively built cars are actually cheaper to run in terms of speed / finish rate and ease to run. As long as you buy wise, they are actually cheaper than building a lesser spec car yourself.
Posted 12th Mar 2013 at 11:33
As Daveyboy says, GKN can probably sort you shafts out, they're pretty good at mixing and matching parts for the motorsports lads.
The other option is to go full on and use 930CV's with the fabricated uprights and rear lock bearings as Welshpug says, it's what the silly spec cars used to run. It's expensive up front (having just had some machined for my car, don't expect much change out of a grand even doing most of the work yourself), but the CV's themselves are cheap and reliable and the longer shafts reduces the plunge and angle change, so you either get less wear and power loss or you can go for more suspension travel.
Posted 12th Mar 2013 at 13:45
yippeekayay
I am sure that gal Ral ran gkn in it and seeing as it went direct from Phil to Sydney and sat in a barn I would phone Simon galliford to get the exact spec and where it came from....
x box "yippeekayaymofo"
Posted 12th Mar 2013 at 14:59
Maxi rally
Yeap thats the reality....
Holinger Engineering (they make a great product) are making up a set of heavy duty custom shafts, not cheap not cheap but very very strong.
They may also copy the gearbox (Ml6c Dog box anyone after one?) BTW the are not cheap, but cheaper than I was quoted for a couple out of Europe / UK
Posted 18th Apr 2013 at 04:34
I'd be very interested, what sort of money are we talking though?
Posted 25th Apr 2013 at 12:34
