Author Subject: car sometimes doesnt start
darzmat
hi guys yet another car doesnt start thread,
i have searched the subject but nothing really relates to what mine is doing.
i had issues at the tail end of november with the car not starting, so i gave up on it and bought a corsa.
now that ive tax'd and tested the corsa i would like to get the pug ready for the road.
before xmas i burnt out the starter by turning it over to much.
so ive fitted a new battery, new starter, new inlet manifold gasket, and new vacuum pump.
it's still the same as before, turns over fine and eventually coughs and splutters into life. but i have to keep the revs up until there is temperature in the engine, usually a minute or two if not it will just die on me.
after letting it drop down to idle and let it run for 5 minutes, you can turn it off and back on again and you would never think anything was wrong with it.
but i know tomorrow morning when i go to start it, it will turn for ages before firing into life.
risking burning out another starter.
any ideas guys??
could it be as simple as a new coolant temp sensor? would a lambda effect the starting of the car?
i lso cleaned out the icv.
any help is much appreciated.
Posted 7th Mar 2013 at 13:01
is it misfiring you mean? and from cold only? sounds like start of HG failure to me. i've had it a few times now and it's always been the same thing. is it using any water? is it smoky? temperatures ok?
Posted 7th Mar 2013 at 13:06
superchargedblack1997gti6
I had an issue like this , I believe it was down to low compression on number 3 piston. I would recommend getting a compression check done. Mine was down to a broken piston.
Ross Thumbs up
Posted 7th Mar 2013 at 13:11
darzmat
no its not misfiring, it just struggles to start, but when it does start its fine. its not using any water, its not smokey and temperatures are fine, always have been,
Posted 7th Mar 2013 at 13:26
Checked various sensors like the CTS?
There's an autodata screen grab in the FAQ section with correct readings.
  • Posted 7th Mar 2013 at 13:29
