Author Subject: Gearbox ratios
superchargedblack1997gti6
Hi guys remember a discussion saying phase one gearboxes have a slightly longer final drive / ratio. Can somebody confirm this for me? Just want to have a box rebuild strengthened and would like the longest ratios possible.
Thanks Thumbs up
Posted 7th Mar 2013 at 13:45
pete_rallye
Yep its true. Can't remember the difference but remember my car wouldn't move when I mixed a crown wheel and pinion up because the teeth locked!
Lap of the 'ring
Posted 7th Mar 2013 at 15:09
Think it was changed for phase 2 onwards as they lowered the rev limit as well possibly.
but yeah they are slightly different
Posted 8th Mar 2013 at 10:33
In that case any gearbox you manage to get hold of that has BE4 stamped on the casing will not have the longer ratio as it was only the earlier BE3's found in Phase 1's which had this.
You may be able to find a difference if you look on Servicebox and use the VIN from a known Phase 1 and a Phase 3 and then see if the part numbers change. Yes
Posted 8th Mar 2013 at 12:56
pete_rallye
If you look on servicebox it shows you the 2 options and the ratios.
Lap of the 'ring
Posted 8th Mar 2013 at 13:00
Thanks for the replys I have a phase one i use as a daily and think I have both a phase 2 and a phase 1 gearbox spare, will check on service box.
Longer ratios all the way
Posted 8th Mar 2013 at 13:10
Out of interest, why do want the ratios to be as long as possible? I have a Super High Boost and the standard ratios (Phase 3) still do not allow me to top out 6th gear on any racetrack I've visited, so what is the benefit that you are looking at for even longer ones?
Posted 8th Mar 2013 at 13:22
pete_rallye
Super mega top speed surely? Or better fuel consumption!
Lap of the 'ring
Posted 8th Mar 2013 at 13:24
Trying to give me the longest ratios, don't want to be hitting the limiter much if I can help it. Already had 4 standard engines in the car and this one is a lot more expensive, would like to be fast without having to bang it off the limiter. + super high top speed will be a bonus. Superman
Posted 8th Mar 2013 at 13:29
its only 3.95 to 4.05.
Posted 8th Mar 2013 at 17:19
Have thought of the 307 six speed gearkit but again no definite answers, wether they will work. A small change is better than nothing Thumbs up
Posted 8th Mar 2013 at 17:30
thats an ML gearbox, not compatible.
Posted 8th Mar 2013 at 17:42
I thought I heard miles saying the internals maybe interchangeable, but am probably wrong. Smile
Posted 8th Mar 2013 at 17:50
Takedown
internals are almost all interchangable
mine is 5 speed BE3
1 and 2nd of a S16
3rd 4rd 5th from a Hdi
great gearbox for a turboed 306... with mega topspeed!!!!!!!! will do 288kmpu with stock revlimiter
Posted 8th Mar 2013 at 17:57
To be honest, I really don't find you need to use extra revs with this setup, it is so very drivable using the standard ratios, I would recommend staying with them, although of course it's your choice. Pete could probably vouch for how well they drive with this setup from when he bought Rich's car. Yes
Posted 8th Mar 2013 at 19:17
pete_rallye
As Welshpug says, I don't think you'll notice a difference between the ratios. Probably see more difference fitting bigger wheels...
Lap of the 'ring
Posted 8th Mar 2013 at 20:29
Rich E Forum Admin
Speed and RPM details here: http://www.306gti6.com/forum/showthread.php?id=123204
I believe a car with the earlier FD will have a VIN containing RFSV instead of RFSW (RFS being the engine code, and the letter after denoting the gearbox).
Some very early phase 2 cars have them as well as the phase 1.
Posted 9th Mar 2013 at 16:07
Thankyou very much Rich E Thumbs up
Posted 9th Mar 2013 at 20:00
Useful information there Rich, nice one. Thumbs up
Posted 9th Mar 2013 at 21:16
