displaying posts 151 to 175 of 183
Pages (8): first .. 6 [7] 8
Author Subject: My Xsara VTS project
IvayloPavlov
Post #151
Posted 6th Jun 2016 at 20:22
IvayloPavlov
Post #152
Posted 8th Jun 2016 at 19:04
IvayloPavlov
Post #153
Posted 12th Jun 2016 at 18:47
IvayloPavlov
Post #154
2 babies, and bottle of ...
Posted 13th Jun 2016 at 20:46
IvayloPavlov
Post #155
.... of Nos
Posted 16th Jul 2016 at 21:37
IvayloPavlov
Post #156
Myltypoint dry system
Posted 17th Jul 2016 at 22:38
IvayloPavlov
Post #157
Posted 18th Jul 2016 at 20:55
IvayloPavlov
Post #158
Some cosmetic job
New silicon hose
Better resistor for Idle Valve
and some wiring
Posted 28th Jul 2016 at 14:13
IvayloPavlov
Post #159
Posted 21st Aug 2016 at 18:01
IvayloPavlov
Post #160
Posted 21st Aug 2016 at 18:05
IvayloPavlov
Post #161
Posted 22nd Aug 2016 at 21:26
IvayloPavlov
Post #162
Posted 23rd Aug 2016 at 21:26
IvayloPavlov
Post #163
Posted 24th Aug 2016 at 20:24
IvayloPavlov
Post #164
Posted 25th Aug 2016 at 22:36
IvayloPavlov
Post #165
Conception was changed.
Posted 4th May 2019 at 22:17
IvayloPavlov
Post #166
Posted 10th Jul 2019 at 00:36
IvayloPavlov
Post #167
Posted 10th Jul 2019 at 22:21
IvayloPavlov
Post #168
Posted 12th Jul 2019 at 14:10
IvayloPavlov
Post #169
Posted 12th Jul 2019 at 14:29
Post #170
Loving these updates, how has your previous gearbox been handling the extra torque?
What sort of power / torque figures is the engine making?
Posted 12th Jul 2019 at 18:51
IvayloPavlov
Post #171
There is no problem at all. I was running standard GTI6 box with Quaife differentials and custom made ceramic clutch. The car was ran only 2 000 km after I put all together @ 14 PSI of boost. I haven't measured on dyno yet, but due to low compression I expect no more than 300 BHP. So after I have changed the bearings and the clutch I am going to high boost +25 PSI.
Here it is what I have as a parts:
customs JR pistons CR 8:1
custom Pauter rods with ARP bolts
King Racing bearing
SS custom exhaust manifolds & downpipe @ 3.5"
SS custom exhaust pipe @ 3" with central Magnex and no brand end box
2 * 40 mm Turbosmart wastegates
50 mm Turbosmart BOV
BorgWarner S200SX-E (the S252) with 0.83 AR twinscroll hot side
13 liters FMIC Mishimoto
inlet turbo pipes at 2.5'
Mocal oil cooler
Aluminum water cooler
2* Mishimoto Heavy Duty fans with custom shroud
custom fuel rail
1 000 cc Bosch motor sport injectors
2l swirl pot internal 044 Bosch motorsport fuel pump
AN8 fuel lines & AN6 returns
Sard fuel regulator
Red top VAG coils
Megasquirt 2
VTS BE3 5 speed gearbox with 205 1.8D Differential
ATB Quaife
Helix clutch
KW v1 coil overs with KAD top mount
VT engine mount
Polyurethane arm bushes
406 Brembo 4 pot with C5 288 mm front discs
Rear Apex dampers
Solid rear mounts
Posted 13th Jul 2019 at 09:31
IvayloPavlov
Post #172
Posted 13th Jul 2019 at 08:49
IvayloPavlov
Post #173
Posted 13th Jul 2019 at 08:50
IvayloPavlov
Post #174
Posted 13th Jul 2019 at 08:58
IvayloPavlov
Post #175
Uprated VM upper engine mount Smile
Posted 13th Jul 2019 at 09:15
