Author Subject: The difference between emerald K3 and K6 ECU
Demograffix.com
Hi does anyone know what differences there are between the two ECU's? is there noticeable difference in the performance. I have spoken to Pug1off and they recommended the K6.
stevenage black gti 6, 198bhp
Posted 7th Apr 2013 at 10:59
http://www.emeraldm3d.com/
Posted 7th Apr 2013 at 11:02
miles
Both do the same, The K6 has a USB port that unless very recent is not used until the software is written for it
Mind having used most it's either Omex, DTA or Motec here, Allot easier to map, better idle mapping as well,
Emerald is just a pain to map as you need to save everything when ever it's changed.
www.pugracing.com
Posted 7th Apr 2013 at 23:15
JWP EFi
Turbo Legend!
does the K6 not have the ability to self map via wide band after you have entered the constants ie, target AFR max rpm etc?
Posted 9th Apr 2013 at 07:42
Demograffix.com
so whats best to go for emerald, omex, DTA or Moretech? Im a newbie to engine tuning iv only ever gone as far as to adding a pipercross viper induction kit to a car. I now have some Jenvey 45 tbi's and im on the look out for a decent ECU and loom. Noticed theres a omex 600 ECU for sale at the moment will this be any good?
Posted 12th Apr 2013 at 16:39
Demograffix.com
was told I should go for an omex 710 by a mate
Posted 12th Apr 2013 at 16:43
is your mate a mapper and will be mapping it for you?
Posted 12th Apr 2013 at 16:54
Demograffix.com
no just a mechanic, dont know any mappers, so i was going to take my car to pug1off. Im based in stevenage and northampton is doable. I dont know anyone else that could do the work nearby.
Posted 12th Apr 2013 at 16:58
There is a very good mapper right here on my doorstep, based in Kimbolton, Cambridgeshire.
They do all sorts of ECU and are very highly regarded within race teams.
Details are found here
Posted 12th Apr 2013 at 19:47
steve and steve at track and road then Thumbs up
they like DTA afaik.
Posted 12th Apr 2013 at 20:54
miles
600 and 710, the only reason to use the 710 is if using 8 injectors or need to stick to the 4 coil pack's with these engine's, But as said the mapper is the main thing as getting the best out of the ECU can mean one hell of allot.
Mind if using Jenvey's make sure you use the longer inlet manifold as the jenvey one will only net you around 175bhp tops on a std engine, you can add another 10 to this number with the longer one
Pugoff use Northampton motorsport for the RR, If it's the best system is up to you.
www.pugracing.com
Posted 13th Apr 2013 at 23:21
+1 for these guys, they know their onions, they also know a thing or two about engines.
They are good on Omex to, they mapped my track Rallye and it ran sweet as a nut before I killed it (my fault, not theirs)
Posted 13th Apr 2013 at 23:56
