Author Subject: 2x sets 2.25" 250lb x 8" 1x 275lb x 8" springs
c_j_m
Looking at selling the coilovers springs I have to fund some shorter and stiffer springs.
They are all 2.25" diameter. And I believe all to be made by AVO.
I have 2 sets of 250lb x 8" springs
1st set are used with surface corrosion, after £30 for these
The 2nd look as new, after £40
Also have 1 set of 275lb x 8"
Again these look as new, after £40
Posted 8th Apr 2013 at 11:38
burnout21
What lbs are standard? Would any of these lower the front end? Cheers.
Posted 8th Apr 2013 at 12:56
c_j_m
Not a clue, but these are for use with coilovers.
Posted 8th Apr 2013 at 12:57
burnout21
I'm looking at getting an estate/vts beam with the stiffer bars, so after setting up the front to match.
The car is only going to be fast road and track use once or twice a year.
Posted 8th Apr 2013 at 14:40
pugheaven
As Chris has said these are springs for COILOVERS and can't be used with standard shocks, you will need to have coilovers already or intending to buy some coilover bodies to accommodate these springs Smile
Posted 8th Apr 2013 at 14:49
c_j_m
Also willing to do a swap for some 5 or 6" 300lb springs too.
Posted 8th Apr 2013 at 15:13
