displaying posts 1 to 25 of 28
| Author | Subject: What standalone ecu |
markylee
Regular Location: benfleet Registered: 05 Jan 2011 Posts: 393 Status: Offline |
Hi I've decided to go the throttle body route, Which ecu shoul I use ? |
Whichever your preferred mapper recommends is usually the way to go. For instance Dave Walker won't do anything other than Emerald (it's his ECU though) whereas lots of guys don't like Emerald much.Most are more than happy to work with Omex or DTA, DTA has a very good reputation and is considered by many to be superior to Omex, depending which model of ECU you buy. If you don't need lots of unnecessary frills like anti-lag and flat shift you can get by with the base model from most manufacturers. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
As above, find a mapper you want to use and take their advice. You really want to be using the brand they prefer the software behind.I use an entry DTA S40 Pro. Still has many features I can't make use of in my 205. ________________________________________ ![]() |
markylee
Cheers guys, and do I definately need this, can I not just use a standard ecu |
You can use the standard ECU, the drawback is that there seems to be only one place in the UK that's able to map the standard ECU (well there will be others that claim they can, but none with Wayne's proven track record) and that's Chip Wizards in Rotherham. I haven't looked where you are based but for many he's a trip to far. The other drawback with mapping the standard ECU is that you are pretty much locked into going back to Wayne for every modification you do that entails a map tweak (updating cams a few months after fitting bodies perhaps) so think carefully about what your future plans will be and do the lot at the same time.Last I heard a Chip Wizards map was £400 and you need to budget for fuel and travel expenses too. Thsts if you can wait for Wayne to fit you in as his waiting list is usually pretty long. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
markylee
daveyboy wrote: cheers mate i'll look into that, Trying to save the pennies where I can at the moment You can use the standard ECU, the drawback is that there seems to be only one place in the UK that's able to map the standard ECU (well there will be others that claim they can, but none with Wayne's proven track record) and that's Chip Wizards in Rotherham. I haven't looked where you are based but for many he's a trip to far. The other drawback with mapping the standard ECU is that you are pretty much locked into going back to Wayne for every modification you do that entails a map tweak (updating cams a few months after fitting bodies perhaps) so think carefully about what your future plans will be and do the lot at the same time. Last I heard a Chip Wizards map was £400 and you need to budget for fuel and travel expenses too. Thsts if you can wait for Wayne to fit you in as his waiting list is usually pretty long. |
JWP EFi
i'm looking to down the tuned n/a route, for me to travel from Edinburgh to Waynes and back plus how ever much fuel the car will consume on the dyno, i'd be looking at a couple of hundred quid plus the actual mapping costs of 400, then as daveyboy says, you would have to go back to wayne for future map revisions. You may as well go Omex, DTA or something. |
Rotherham? He must have moved ![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Rochester then! Can't get away with anything on this forum, just ask Stan!________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
http://en.wikipedia.org/wiki/Rochester,_Kent________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
http://en.wikipedia.org/wiki/Rochdale ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Do one, bastids ![]() ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Sorry Dave.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
stan_306gti6
daveyboy wrote: Rochester then! Can't get away with anything on this forum, just ask Stan! Explain please... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6 wrote: daveyboy wrote: Rochester then! Can't get away with anything on this forum, just ask Stan! Explain please... Somebody is always watching... ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
markylee
Hi has anybody got a contact no. for wayne as rochester isnt that far from me |
Welshpug is his secretary, drop him a PM, I'm sure he'll have his details ![]() ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
. Read the thread, then google chipwizards________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
markylee
welshpug! wrote: Done that and it looks like the website's down, hence why I asked for a contact no. lmao . Read the thread, then google chipwizards |
Meeooww!! ![]() ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
markylee
Too early for me, I'm grouchy this early |
Theres a thread on north west remap, ask the op for waynes number as he mapped his car on mondayHe was based in Rochdale, not Rochester but now apparently works out of Warrington, cheshire________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
markylee
coskev wrote: Cheers mate, very helpful Theres a thread on north west remap, ask the op for waynes number as he mapped his car on monday He was based in Rochdale, not Rochester but now apparently works out of Warrington, cheshire |
