Author Subject: testing coil packs....
stilly
hi all....how would i go about testing the coil packs to see if they are faulty.....i may have an issue with one of mine, but its an intermitten thing....i have 8 spare, but not sure if any are also faulty....just want to check to make sure any are good...cheers boys and girls...Thumbs up
deaf in 1 eye blind in 1 ear Crazy......
307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
Posted 10th Apr 2013 at 20:47
Check the resistance across the terminals would be a good start.
Is it a misfire issue or something else?
Posted 10th Apr 2013 at 21:47
stilly
a bit of holding back as i low revs pulling away...normally in 2nd and 3rd gear....still goner get a new lambda like you said, but i may as well try 4 other coil packs as i have 8 sitting about doing nothing...
Posted 10th Apr 2013 at 21:57
Coil packs *usually* break down at higher rpm, not always but usually. Yes
Posted 11th Apr 2013 at 11:51
mike rallye
What sort of rpm would you say they break down? The reason i ask is I till got this hesitation fault on idle (but it goes after couple of seconds or if I just touch the throttle), but sometime it hesitation round 2rpm .could this be a coil breaking down?
Posted 11th Apr 2013 at 20:35
More than likely the lambda. Yes
Posted 11th Apr 2013 at 20:43
mike rallye
Have fitted new lambda just over a year ago
Posted 11th Apr 2013 at 21:05
Could still be lambda, parts can fail at any time. Especially cheaper pattern parts.
Posted 11th Apr 2013 at 21:18
mike rallye
Ok then i get a new one at the end of the month, what make should i get, bosch?
Posted 11th Apr 2013 at 21:28
Should get it tested first, do you have a friendly mechanic that's got diagnostic tools?
Posted 11th Apr 2013 at 21:40
As Jim says, testing it first will be the best option. Yes
If you do need a new one then yes, Bosch is recommended as these are OEM fit. Smile
Posted 12th Apr 2013 at 07:14
stilly
ordered my lambda from sc's....£65 all in and its a bosch one.....happy days
Posted 12th Apr 2013 at 07:44
