Author Subject: 306 S16 ish
miles
A very long winded project this one, some of you know it as I've had the car around 7 years now buying off a mate from London with a dead bottom end to replace my old 309 Race car
I'll add a proper description as I go along but some pic's to start with
First off how it started with a fully stripped car and mild spec engine, Steel Rods, JE Piston's, Head and some Kent cams with mere pin hole 45mm bodies
Then
Much better and allot Lighter being 50's
Engine on the stand, new spec is basically
Sanex Rods
JE Pistons
Mad Pete Head with larger inlets and flowed nicely (I hope)
Solid Lifters with Cat cams 4903272 with a huge 13.75 lift
Extra Long Inlet manfold
Renault Pico Injectors
Vibration free complete engine balance and weight matching
Omex 600 ECU with full throttle shift
http://i940.photobucket.com/albums/ad248/pugracing/IMG_1469.jpg
Beam with 21mm Bars and a 30mm ARB, Xsara rear arms
Then onto the box, The most hybrid box ever I think, with BE1, BE3 and BE4 parts to make a nice C/R box with a 4.9 CWP complete with a very stiff 3J Driveline Plate Diff
The onto the modded SD cage so I can fit Harness bars, Never liked fitting them to the shell behind the seat after this
Exhaust manifold now in production after test fitting on mine
And as it is now, almost complete
Over the winter a steel crank will be fitted and some more work, Maybe different cams again to nude the 300bhp mark, Will be able to go over 9000 rpm then along with a Omex 710 ECU
But around the 250 mark is what the cams are good for, So if I change the timing, Trumpet lengths etc we will see a increase as we ran out of time with 15 hours on the Roller's it's not cheap even at mates rates
See's getting polished up by a mate on Thursday
www.pugracing.com
Posted 15th Apr 2013 at 21:58
The steel crank, does that have the same con-rod journal sizes? IE is it a straight swap for a standard crank? And how much Wonga are we talking to get on as well? Cheaper if you buy two is what I'm getting at.
PM me if you want to keep the details under your hat.
Ta
Plus I really want one of those ally engine top mounts and the bracket on the lump itself. Talk to me LOL
Posted 17th Apr 2013 at 11:21
miles
Crank's coming from a mate for a mere bag of sand with std bearings, Otherwise as you know they do cost allot.
Mount is from a XM 8v Turbo, but find one of those these days
www.pugracing.com
Posted 18th Apr 2013 at 02:17
It is getting harder to find some of these bits and bobs now isn't it?
Cheers anyway.
Posted 18th Apr 2013 at 06:48
miles
All going well, little write up from the weekend via this link, http://www.gurstondown.org/
www.pugracing.com
Posted 22nd Apr 2013 at 20:52
blandy
Saw your results on fb you must be chuffed now its all coming together
Posted 22nd Apr 2013 at 21:01
miles
Getting there, A few bit's still to come suspension wise but basically the set up's good enough, another 306 turned up too on Sunday, He came over asking if I had strut braces etc and was quite puzzled when I said 'no' and a waste of time unless you've got a weld in cage.
www.pugracing.com
Posted 22nd Apr 2013 at 21:16
Jake
Oooh would love and engine like that, will rev up nicely. We need track vids!
Will you be taking this racing or is this the sprint car?
The 205
205 GTI6 For Sale
Off Racing!
Posted 22nd Apr 2013 at 21:48
miles
Just the local hillclimb currently, Family working hours etc means this is it at the moment, Mind only another 1 or so and my daughter may start karting so I'll be broke then
www.pugracing.com
Posted 22nd Apr 2013 at 22:10
miles
Well after some use the time has come to swap everything over into another 306 thanks to the rules, Joys I guess of building a car for something else then changing my mind as normal, so from this
Back into
The blue one will be up for sale without cage and engine
www.pugracing.com
Posted 7th Jan 2014 at 22:41
p-silva21
Good project Thumbs up what wheels and brake setup are you using?
Posted 17th Jan 2014 at 22:34
