Author Subject: max rpm for forged low comp engine????
Takedown
Im going to build a spare S16 engine with forged pistons and rods (turbo)
What is the max rpm you could run safely on the S16 engine?
thankyou
Posted 18th Apr 2013 at 23:38
Depends on the quality of your rods, pistons, crank and his thorough you are during the build. But 9k is possible if hour pockets are deep enough. Why do you need all those revs on a turbo lump though?
Posted 18th Apr 2013 at 23:49
Takedown
I dont want crazy 9K revs.. just seeing if 7.5K is safe? , what about the valves? hovering valves?
Posted 18th Apr 2013 at 23:52
7.5k? That's not far off standard LOL decent gear should be good for 8k
As for valve float, operate the springs. I'd stick with hydraulic lifters though unless you want to go more than 7.5-8k
Posted 19th Apr 2013 at 00:01
Exactly, limit on my supercharged engine with standard internals is set at 7650 and that's safe coz I've hit it a few times lol
Posted 19th Apr 2013 at 00:33
Takedown
standard is 6750?
Think 7400 is nice
thankyou for the info
BTW where can i get upgraded shellbearings(rod bearings) for the S16?
Posted 19th Apr 2013 at 10:06
Which S16 do you mean?
If its the one that is a Gti-6 jsut european then Phase 1's are set to 7500 rpm and Phase 2 onwards are 7250.
The car we call the s16 with the 5 speed box is 7.4k iirc
Posted 19th Apr 2013 at 10:26
the RFY goes to 7k, peak power is @6800, peak torque @4100.
Posted 19th Apr 2013 at 10:55
Takedown
Im talking about the 1994 XU10J4 2.0 S16 with the 5 box
im sure that one doesnt go past 7K
Posted 19th Apr 2013 at 11:10
24seven
What you see on the dashboard and what the engine is actually doing can be very different sometimes. 7500 should be effortlessly achievable providing the engine is assembled to a decent standard.
Posted 19th Apr 2013 at 11:30
they do, just.
Posted 19th Apr 2013 at 12:07
Takedown
Oke thankyou Welsh, i Always thought it was around 6800
Posted 19th Apr 2013 at 23:16
IvayloPavlov
Hi, wonder if I can pass 8K RPM with standard springs and hydro lifters. I need to go over 8.2 to pass 100-200 km/h without shifting. Smile
Posted 14th May 2021 at 15:48
not advisable, power drops off after 6500 so ahifting would be faster, before considering that the hydraulic tappets do not work so well beyond 7800 regularly
ise a bigger tyre or longer final drive if you need to, thats a weird thing to need though
Posted 15th May 2021 at 09:12
IvayloPavlov
With my old setup the power drops after 7 200 rpm. I am installing cams with more lift, bigger turbo, ARP studs, Cometic gasket and more boost combined with water-methanol.
My ML5 gearbox is with the longest FD from 2.2 HDi. And biggest possible tyres.
Posted 18th May 2021 at 22:21
