Author Subject: Combe 27/4 collection items
Going to Castle Combe on Saturday to the Spring Action Day - so if anyone wants any bits and pieces, I can bring them along.
Some random larger 306 bits that have come to mind:
Boge front shocks in good condition with no leaks. Fitted with nearly new springs in brilliant condition. I've been meaning to split them down and sell the springs alone but haven't got round to it. £20 for the pair fully assembled with top mounts.
Pair of driveshafts. Good boots - £30
Twin fans in housing. Good condition - £15
Genuine wishbones ripe for roller bearing conversion - £10 pair
Bare inlet manifold - £15
Throttle body with ITS - £5
Heater matrix pipes in good condition x 2 - £5 each
Nile blue grill - £5
Pair of rear lights with bulb holders - £5
Plus hundreds of other random smaller pieces and interior whatsits. Fire away as I can bring stuff if I have it.
Some other random bits and pieces for our 205/309 owners
Diesel 205 twin cooling fans in housing. Very good condition - £15
309 GTi trailing arms with disc hubs. Complete with reusable shafts if you turn them around - £20 pair
205 GTi ARB and end plates £20
1.6 8v flywheel. Common upgrade for 1.9 owners as it's a lighter item and a straight swap - £20
8v GTi inlet manifold with fuel rail and FPR - £15
8v GTi inlet manifold with fuel rail, injectors and FPR. Throttle body included. Untested so unsure of injector condition. Would advise an ultrasonic clean - £20 complete
8v cam cover ideal for painting/polishing - £5
Again, have various 205 bits knocking about from ones I have broken previously so fire away and I can pop them in a box and bring with.
  • Posted 24th Apr 2013 at 13:53
    pebbles167
    Got any random Peugeot locking wheel adapters lurking about? Can't get my wheels off Sad
    2005 Peugeot 206 GTI 180
    2008 BMW K1200R
    Posted 24th Apr 2013 at 14:36
    Chances of them being the same fitting is small, but I do have a couple somewhere and can bring them to try? Personally I'd just hammer a socket on them and remove.
  • Posted 24th Apr 2013 at 14:43
    pebbles167
    I tried, but these are on TIGHT. would probably require drilling.
    Worth a shot with the keys though, I found another scrap d turbo with the same adapter... Then binned it.
    2008 BMW K1200R
    Posted 24th Apr 2013 at 15:01
    Do you have the s**tty pin key or the equally as s**tty slotted round ones?
  • Posted 24th Apr 2013 at 15:07
    pebbles167
    The s**tty 4 point pin key.
    Very s**tty
    2008 BMW K1200R
    Posted 24th Apr 2013 at 15:46
    RetroPug
    Very s**tty
    My adapter for these broke the first time I removed the wheels.
    Very s**tty indeed.
    Posted 24th Apr 2013 at 18:59
