displaying posts 26 to 48 of 48
Pages (2): 1 [2]
Author Subject: Couple of queries
jord294
Did whoever who built the beam fit the arb? As my thoughts are that, apart from not setting the height to suit the thicker torsion bars, the splines and end caps may not of been lined up when that was fitted.
This can cause the car to sit higher on one side as the trailing arm has been forced up/down to get the 8mm bolt in
Posted 27th Apr 2013 at 20:18
atterz
Make that 300mm, which means that it was lowered -30mm on standard bars, therefore it was a simple case of the lack of sag not being taken into account!
Im measuring the sill heights where you say Mei and just double checked and they haven't changed.
I hadn't considered that Jord! But everything was done at the same time.
owain wrote:
Posted 27th Apr 2013 at 20:23
simonjames
-30 at spring doesnt give -30 height would be around 45mm
MY EBAY ITEMS
07943066306
Posted 27th Apr 2013 at 20:28
but not on 23mm bars.
Posted 27th Apr 2013 at 20:31
atterz
:S
Side view as it currently stands!
Posted 27th Apr 2013 at 20:34
simonjames
positive camber ? or just how im seeing it (on my 5th can by the way LOL)
MY EBAY ITEMS
07943066306
Posted 27th Apr 2013 at 20:37
atterz
Haha cracking, nah no camber Smile
Posted 27th Apr 2013 at 20:40
jord294
322mm between shocker mounts using std 20mm bars would give approx 30mm drop
316mm between shocker mounts using vts 21mm bars would give approx 30mm drop
So that's why I said, a distance of approx 310mm between the shocker mounts using your larger bars should be pretty much bang on.
At least with coilovers on the front, you can fine tune the rake
simonjames
sorry i didnt take in to account different bars
MY EBAY ITEMS
07943066306
Posted 27th Apr 2013 at 20:41
atterz
Post #35
So im kind of confusing myself over nothing then? I just cant understand why the rear sills seams so high?
Posted 27th Apr 2013 at 20:43
jord294
Post #36
Personally, I think it is a touch high at the back.
Posted 27th Apr 2013 at 20:46
atterz
Post #37
I thought so to, i have no more adjustment at the front and the rake angle is still to high for my liking. Hopefuly get it sorted this month then and drop her a little more.
Posted 27th Apr 2013 at 20:48
jord294
Post #38
surely whoever built the beam for you, would be willing to re-adjust it to how you want it?
Posted 27th Apr 2013 at 20:57
atterz
Post #39
I have no doubts he would, im just gonna be down in Wales now for quite a while so wont be anywhere near him!
Posted 28th Apr 2013 at 13:08
Post #40
Mei could do it for you
Posted 29th Apr 2013 at 07:43
simonjames
Post #41
Where abouts in S.Wales are you ?
MY EBAY ITEMS
07943066306
Posted 29th Apr 2013 at 20:54
atterz
Post #42
St Athans mate, i need to enquire with yourself where you got your cage made and fitted mate.
Adam - I would appreciate any help so shall ask!
Posted 29th Apr 2013 at 22:17
jamiek_uk2000
Post #43
I've just asked him exactly the same thing, his cage is exactly what I want.
R&R Racing
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 29th Apr 2013 at 22:22
atterz
Post #44
Awesome cheers mate! If anybody in S.Wales needs a hand with anything im available most weekends! Would really appreciate the help Mei if possible, beer tokens your way obviously!
Posted 30th Apr 2013 at 13:07
jamiek_uk2000
Post #45
I shall let you know, if I get this cage I'm sure I'll need some assistance with the dash removal. I may well get it flocked whilst it is out aswell then?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 30th Apr 2013 at 13:10
atterz
Post #46
Not a problem mate more than happy to help out!
Posted 30th Apr 2013 at 16:25
iplay
Post #47
The driveway does not look flat.
It needs to be totally flat to get accurate measurements.
10-15 mm of rake for standard setup.
Posted 2nd May 2013 at 13:03
atterz
Post #48
To save for a new thread im wondering if these are likely to have the damping rates required to control the rear :http://www.peterlloydrallying.co.uk/index.php?route=product/product&path=130&product_id=890 ? With regards to the front im going to get some 9 inch 325-350 springs as the fronts keep coilbinding and the car tripods massively.
Posted 9th May 2013 at 11:58
Pages (2): 1 [2]
