Author Subject: 406 v6 brake master cylinder
7057sam
Hi need the above as I'll purchasing my brembo s soon
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 1st May 2013 at 00:03
JWP EFi
Turbo Legend!
iirc its the same as what youve got...288's should be in today, be in touch later
Posted 1st May 2013 at 07:21
Ep, its the same bore as a gti6/rallye/vts/zx16v. All 406's use 23.8.
Posted 1st May 2013 at 07:41
Just make sure you got braided lines all round and BLEED THEM PROPERLY! Pedal travel is almost the same as a standard 6 on mine now with 406 brembos (on 330mm rotors) and braided lines. I found with mine they were fine for a while after bleeding but pedal went crap and had to re- bleed. Did the rears at the same time and pedal is lovely now. Master cylinder is the same diameter as the 6 one anyway.
Also have you purchased the brembos yet? If not I have a pair sat around I'd let go cheap as their not an exact pair just different brake lines/ inputs.
Posted 1st May 2013 at 18:39
7057sam
Thanks for the advice buddy yes they in the post tomorrow, very excited
Rallye dead Sad
Posted 1st May 2013 at 22:26
Nice one. Just get someone to help you bleed them. The last 2 times I attached a tube to the nipples and submerged the end of said tube in a jar of brake fluid. It makes sure that no air can possibly get into the system but was still locking and un-locking the nipple every time someone pumped the pedal as well if you get me. Still got a lovely pedal now Big grin but that's with all 4 braided lines.
Had to replace both rear callipers at the same time though as the nipples were stuck and snapped. Got 206 gti180 ones off eBay for £20 lol
Posted 3rd May 2013 at 08:12
