Team dynamic 1.2 direct fit in 16s with no spacers FIT over the 406 brembo 330 rotor kit
You can only squeeze a rizzla or two in between the brake calliper and wheel but that's all you need
I have a pic so will up load when I get a chance
displaying posts 1 to 25 of 28
| Author | Subject: 16s over 330 kit do fit |
jamiek_uk2000
That will be good for some people, I'm sure I'll be employing this information once I go charged ![]() ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
I new they would be close there's loads of room under both my sets of 17's so thought some lightweight 16's would be a possibility ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
fordygti
Seasoned Pro Location: Walpole St Andrew Registered: 07 Dec 2009 Posts: 1,257 Status: Offline |
That's surprising, I've got the 310 Renault sport kit with 16s and it the same gap as yours. Suppose theybare different calipers.So far the only set.of wheels I can find to fit them are pro race 1.2s. ________________________________________ 98 onyx black 306 Rallye53 Nissan Primastar silver (work horse) 58 black Volvo c30 sport |
If you track it they'll rub because of wheel flex. Watch out for potholes too as the slightest buckle will cause you problems and trap a stone behind the calliper and you can cut the wheel in half.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
I was thinking if you hack it round a corner hard the wheel will surely bend a little under load as will the bearing and hub etc so may rub________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
aaron6
Get some 2-3mm spacers made and it'll be cool. A machine shop wont be too dear for these.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
I have some correct bore 5mm spacers for sale ![]() ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
aaron6
There you go. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
ash
Six Addict Location: Chelmsford Registered: 25 Mar 2003 Posts: 7,520 Status: Offline |
I have some 330mm v6 brembo kits left |
You bunch of clowns There is loads of clearance from the spokes it's the inside of the wheel that is close the only thing that will be a problem will be wheel weights |
bigbadbowen wrote: You bunch of clowns There is loads of clearance from the spokes it's the inside of the wheel that is close the only thing that will be a problem will be wheel weights And wheel flex, if it really is that tight. Anything less than 5mm is a bit tight. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
ian7675
Techno Viking Location: Gloucestershire Registered: 12 Oct 2007 Posts: 6,068 Status: Offline |
bigbadbowen wrote: You bunch of clowns There is loads of clearance from the spokes it's the inside of the wheel that is close the only thing that will be a problem will be wheel weights ...but surely everyone on this site knows what they're talking about ![]() ________________________________________ Less than 24 hours to go! |
rallyeash
My old 266 4 pots were like 2mm clearance from the rim, I had to file down the ears of the pads so they wouldn't touch. Did 2 years on track with no issues. ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Wheel weights set back?I had to do this with my GTi6 calipers on 205 1.9 Speedlines? ________________________________________ ![]() |
fordygti
Yh I had to get my wheels rebalenced witht he weights set back. ________________________________________ 98 onyx black 306 Rallye53 Nissan Primastar silver (work horse) 58 black Volvo c30 sport |
rallyeash
Nah were steels so banged on the out side of the inner lip________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
yippeekayay
Seasoned Pro Location: wilts Registered: 27 Oct 2008 Posts: 4,144 Status: Offline |
my 330mms are still for sale too....________________________________________ 306 less for first time in nearly 7 years. Lets keep it that way... please refuse any offers i make to buy your 306 ( doctors letter supplied by request)Marmite and cheese sandwiches anyone??? Burns and Mcrae will be forever missed. x box "yippeekayaymofo" |
eddy_gti6
is this right? Interesting...________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Yup but weights will need to be placed accurately to fit |
steve h gti-6
Location: Carterton Registered: 04 Dec 2006 Posts: 1,583 Status: Offline |
Cool picture and now I know my 310mm Tarox 6 Pots setup will fit behind 16" Pro Race 1.2's if your 330 setup does LoL !________________________________________ "Gotta Love The 6"According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL ! |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
My 330 radix fitted behind 16s so 310 will easily |
steve h gti-6
pugheaven wrote: My 330 radix fitted behind 16s so 310 will easily Sweet just need to save some cash as just bought some 17 Audi TT Ronals for works car as the 15;s on it were poo. Yes I know its a work car diesel workhorse but the wheels had to go lol.Pro Race 1.2's 16" yes thankyou very much. ________________________________________ "Gotta Love The 6"According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL ! |
jamiek_uk2000
Anyone know if any other wheels do, I've got a set of A: PR1.2's B: Turinis C: Speedline 2108's I know that the PR's will, but I may swap the other wheels if they don't ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
6waysforward
Seasoned Pro Location: Benfleet essex Registered: 30 Oct 2005 Posts: 3,168 Status: Offline |
my 16" ultraleggera's dont fit over my 330 renault brembo set up ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
