Author Subject: n/s passenger hub
allye
In need of a near side hub as this happened last Friday and it turns out the 309 has 306 hubs fitted.
Will need it posted to Weymouth.
Many thanks, Ali
205 Van SC'd GTI6 - because why not
309 Goodwood V6 - sold
205 Rallye GTI6 - Bent
Posted 7th May 2013 at 19:49
fordygti
What size bud?
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 7th May 2013 at 21:54
allye
16mm please!
Posted 7th May 2013 at 22:08
fordygti
Measure the hole diameter. If its pulled apart due to the crack.try the ball joint.
Posted 7th May 2013 at 22:09
allye
the ball joint has had it, replacing the wish bone. You think this might be why it failed?
Posted 7th May 2013 at 22:12
jamiek_uk2000
Well if your replacing the whole thing then it doesn't matter as you can get the ball joint to suit the hub, only thing is you may have two different sizes on the car
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 7th May 2013 at 22:16
dendle89
How on earth did that happen ??
Team 6 Cylinders
Posted 7th May 2013 at 22:17
JWP EFi
Turbo Legend!
other than crash damaged cars ive seen this twice, some people use a hammer and chisel to open up the gap to help remove ball joint, hence weakening the casting, all it would take is a decent pot hole to do the above
Posted 7th May 2013 at 22:18
allye
Jamie, you cannot change the ball joints on 309's or 205's.
Dendle, I was going around a bumpy corner. Seems the pinch bolt could have been too tight meaning it was under stress. Or as Fordy mention the ball joint was knackered so this may have contributed.
Posted 7th May 2013 at 22:19
jamiek_uk2000
Ah yes, it's all flooding back to me now. If they are the same as the 205 then they are 16mm hubs
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 7th May 2013 at 22:24
allye
Yep, it is 16mm I need!
Posted 7th May 2013 at 22:25
jonnie205
£28 delivered
Posted 8th May 2013 at 08:50
