Author Subject: Spark plug socket size?
braymond
qu'est ce que??
Rallye-R
Nurburgring article
Posted 8th May 2013 at 14:22
stu
16mm.
I'm sure someone will correct me if I'm wrong though.
Posted 8th May 2013 at 14:29
braymond
Thanks
Rallye-R
Nurburgring article
Posted 8th May 2013 at 14:56
16mm is correct. Yes
Posted 9th May 2013 at 14:26
often called 10mm, as that's the thread size.
Posted 9th May 2013 at 15:52
beez_neez_gt
When getting a new socket for them then try get a magnet spark plug version type, will make changing them far easier.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 9th May 2013 at 15:57
braymond
What's the appropriate torque for plugs? I've always thought finger tight + half a turn but I'm sure there's a something more precise..
Rallye-R
Nurburgring article
Posted 9th May 2013 at 16:03
third of a turn IIRC says the side of the NGK box.
Posted 9th May 2013 at 16:19
beez_neez_gt
25 Nm 18 lbf to be pricise.
Pug fee`ver,
Posted 9th May 2013 at 18:15
Just tighten till you feel the crush washer fully squished. Simple as that.
Posted 9th May 2013 at 18:23
with some guys lack of "feel" for how tight stuff should be, that's not a wise recommendation,
Posted 9th May 2013 at 19:13
dcc
monkey tighten.
205 GTI
Xsara HDI
Posted 9th May 2013 at 19:16
Definitely not "FML Daniel has worked on this car before" tighten...
Posted 9th May 2013 at 19:27
Depends if the plugs are new or not.
If they are new, it's generally finger tight then half a turn to crush the washer. If they are used then a quarter of a turn as the washer will have already been crushed.
Posted 9th May 2013 at 19:58
beez_neez_gt
Or as what a pro does is use a torque wrench.
Doesnt the spark plug end have to be in at the right distance using the torque setting?
Also as i do apply some copper grease around the top of threads so they dont get seized in etc.
Pug fee`ver,
Posted 9th May 2013 at 20:17
