Author Subject: Masking Headlights
calibra306
Did a set of Valeo headlights which i must say although time consuming im quite enjoying doing them.
Heres a few pics.
V6 Power!
Faster I can go the better!
Posted 8th May 2013 at 22:27
pebbles167
What do you do? Oven the lights apart, remove the various bits, spray them black and stick them back on?
Looks well done, How long do you think they took to do?
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 8th May 2013 at 22:34
jamiek_uk2000
Why don't you send me those and you can practice on mine then, make sure you've got the technique nailed.....
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 8th May 2013 at 22:36
gti6girl
Cause their mine Wink
Posted 8th May 2013 at 22:38
calibra306
Just remove adjuster motor and bulbs, leave the wiring plug etc
Some say dont pre heat oven but i find it better when its at temp i do it at 80oc mine was fan assisted but 15-20 min and you want the light barely touchable by hand and if you feel the plastic you will feel it starts to get soft this is where ya want to take it out and get started.
I go round with a Stanley blade lightly oiled then pop back in to warm back up remove and get a screwdriver ad prise under the lens nearest the grill at the top and start to prise out.
sometimes it can be challenging but sometimes the lens comes out pretty easy and ive only done valeo ones.
rub chrome off, i use green and red scotch pads and then spray black etc never touch after use tabs to handle on the bottom, top, let the reflectors fully dry, put back in, seal and leave sealant to go off with a bit of duck tape to keep it on tight until dry.
time can vary took me a couple of hours inc oven times to remove lenses, then you have to remove old sealant which is the most time consuming part.
i did have a problem with the other reflector, with the chrome removed after spraying the plastic had signs of cracks so i got a spare headlight cheap to use for spares.
Done
Ive got 2 spare sets on there way as i want to do mine and then i will do a set to sell (exchange if required as easier)
I hope im not stepping on anyones toes if i do start doing a few for members.
V6 Power!
Posted 8th May 2013 at 22:49
calibra306
Sure are mate. Thumbs up
V6 Power!
Posted 8th May 2013 at 22:50
pebbles167
Nice, I know how ill be burning my house down tomorrow then Thumbs up
Cheers for the guide!
2008 BMW K1200R
Posted 8th May 2013 at 22:57
calibra306
Make sure all the chrome is removed, you can use sand paper but fine wet and dry, just enough to lightly key surface not scratch.
The sprayer at work was gonna water base paint them for me but he recommended just to be safe a paint which has anti flake, anti knock and a good temp resistance to it so hopefully they should stand the test of time!
V6 Power!
Posted 8th May 2013 at 23:04
rich306
I find it's much more fun with a Heat gun :p
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 11th May 2013 at 21:47
calibra306
Sod using a heat gun more chance of f**king the lens up but burning and bubbling it lol
Each to there own as they say
V6 Power!
Posted 11th May 2013 at 21:55
Tallguy_2
I found a heat gun did the trick on mine, wave it along to slowly heat it and then ease apart, both stripped within 15 minutes
"winners come and go but legends never die..."
autorite-sport.co.uk
Posted 11th May 2013 at 23:33
I've done a couple o sets of valeos in my oven and some come apart without to much hassle others you have to keep them so hot the plastic is literally about to melt before the glue gives in. Managed to f**k one light it was so solid. Depos are easy Big grin.
Posted 12th May 2013 at 18:34
calibra306
Yeah first one was like that then the other side came off relatively easy.
V6 Power!
Posted 12th May 2013 at 18:40
Puggie
Heat gun is the method i used took me about 15 min's to crack the cases Thumbs up
Posted 12th May 2013 at 18:54
mellowr1
checked my crystals i bought to fit on my phase 2 and they are valeos...which is a resultThumbs up
Posted 16th May 2013 at 22:27
