Author Subject: idle /running problems , help needed driving me mad
mike rallye
After putting a want section for some parts and replying back to the replies I had .I thought I put my video in this section .hoping someone would of had this fault, as i cant keep driving it like this.
https://www.youtube.com/watch?v=qQB5OERgCtY&feature=youtube_gdata_player
Posted 12th May 2013 at 21:59
Rich E Forum Admin
It says the video is private.
Posted 12th May 2013 at 22:21
mike rallye
Do you know how i change it? As i can view it ok
Does it work know ,i changed a setting ?
Posted 13th May 2013 at 18:50
mike rallye
Well spend some time this evening after work ,and i have seemed to have fix the fault and all seems to be running good at the moment
Posted 13th May 2013 at 19:54
mike rallye
Well I havent completely sorted the problem it still doesnt idle right some days, regarding to what rich e said .that the breather pipe on icv should stall if I put my finger on the end is that right? As it doesnt stall but it idles spot on with my finger on the end as it is sucking my finger as in vacum .
So I need helps and ideas of what to check next.
Posted 16th May 2013 at 18:20
7057sam
I actually have the same problem I first thought it was pas sensor but now think its mine icv breather filter.
Does yours whistle?
Maybe re route the pipe into the induction kit?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 16th May 2013 at 19:11
mike rallye
No mine doesnt whistle, I have tryed new icv valve to, and made no odd with the pas disconnected either. Am wounder if it could be airbox resistor? but woundering what other guys suggest to.
Iwould need the new elbow pipe to fit the new breather pipe into it
Were is the throttle body heater guys. ?
Posted 16th May 2013 at 19:34
The throttle body heater is a yellow device on the front of the throttle body, towards the radiator. Thumbs up
Posted 16th May 2013 at 22:06
mike rallye
Cheers stan, was woundering if this would affect my idling issues?
Posted 16th May 2013 at 22:28
More than likely not to be honest. When you run a supercharger, that part gets removed and gives no idle issues. Smile
Posted 17th May 2013 at 06:42
mike rallye
Well I still got this fault which is driving me mad .some days it will idle and drive spot on amd other days it wont idle and undrivable .
I have fitted new icv, tryed different lambda made no difference. Disconnect the pas and made no difference. Also fitted new map sensor
Could the airbox resistor be at fault? otherwise what else should I look at guys?
Comments and advice welcome
Posted 21st May 2013 at 18:40
Have you had it on a diagnostics machine?Dunno
Posted 21st May 2013 at 20:55
mike rallye
No not yet, cant get to one
Posted 21st May 2013 at 21:00
