Author Subject: Ditching ABS
JWP EFi
Turbo Legend!
what bits do i need to bin the abs pump?
Posted 26th May 2013 at 20:16
2 T pieces, roll of copper pipe, some pipe fittings and a bias valve if your binning compensator tooThumbs up
Posted 26th May 2013 at 20:19
JWP EFi
Turbo Legend!
so basically just tee each wheel off? Iv'e binned compensators on my last 2 6's and never had an issue
this is a 2001 so doesn't have beam mounted compensator
Posted 26th May 2013 at 20:32
Rich E Forum Admin
That suggests there's been something wrong with the rear brakes on your previous cars.
If you don't do something to sort the bias then you'll get 50/50 distribution so you should be able to lock the rears easily under heavy braking, which is quite bad from a safety perspective, especially if removing the ABS.
Posted 26th May 2013 at 20:37
JWP EFi
Turbo Legend!
i see what your saying but my ph2 6 has new rear calipers and i replaced master cylinder too, the brakes are great yet ive never had the rears lock up even in the wet
I may just fit a bias valve on this one though
Posted 26th May 2013 at 20:40
Rich E Forum Admin
On a phase 3 you can simulate the effects of this by unplugging the ABS. This will kill the EBD and give you 50/50 distribution.
Take it out for a drive and if you can't feel the difference in brake force distribution or can't get the rears to lock then something is wrong somewhere. Obviously do this carefully though!
Posted 26th May 2013 at 20:45
eddy_gti6
Or buy my full braided brake line kit with bias and fluid included Wink
Posted 27th May 2013 at 07:10
JWP EFi
Turbo Legend!
was waiting for that one chris, you'll need it for your next investment no??
Posted 27th May 2013 at 19:25
eddy_gti6
I have no use for them mate. Next car is going to have mint condition complete recaro interior as you have seen.
Posted 27th May 2013 at 21:30
