displaying posts 26 to 38 of 38
Pages (2): 1 [2]
Author Subject: removing doors skins
pete_rallye
after a reet f**k about with the couriers these finally arrives this morning. Not had a chance to unpack them yet but will do weight comparisons etc soon!
Lap of the 'ring
Posted 22nd Jun 2013 at 15:57
midlife
Cool
Team 330™Cool
Team "no front end or engine"
Posted 22nd Jun 2013 at 16:06
pete_rallye
Posted 22nd Jun 2013 at 21:44
pete_rallye
OK, so removed my door skin (stop sniggering at the back). The outer skin is rolled over the inner frame and is actually reasonably straight forward t remove. This one tok me about 2 hours, but the second one will be done a lot quicker.
Heres pics-
1st up, a good selection of power tools!
and a good selection of h+s stuff
1st up I heated up and removed the sealant, wasn't really necessary to heat it up as it was quite a warm day anyway and it came off pretty easy
Then you can see how the outer skin is rolled over the frame
Then you prise up the rolled over edge-
I used a set of grips to keep rolling it back-
soon got bored of that so ran an angle grinder down the outer skin, above where the frame is, which allowed me to just pull off the remaining bit of metal-
[URL=http://s109.photobucket.com/user/pete_rallye/media/DSC04033.jpg.html]
[/URL]
I found the angle grinder method easiest so repeated it around the whole door. Just make sure you cut where there is a gap behind the outer skin, so you don't also cut the framework-
This bit just fell out once I cut around it-
and same again on the other side, be careful here as there thicker metal just below the outer skin which supports the hinges etc-
outer skin off-
side impact barrier removed-
then everything else!-
not got anything to bond it on with yet but looks like a good fit...
Lap of the 'ring
Posted 23rd Jun 2013 at 21:32
pete_rallye
weight wise, I removed 8.9kg of metal from the door, the fiberglass door skin weighs in at 2.9kg which means I will save 6kg/door, not masses for the amount of effort involved,but the second skin will be done a lot quicker, as is always the way.
Fordy also said he can do a full door in f/g which might wel be the way forward for maximum weight saving and a lot less hassle!
Lap of the 'ring
Posted 23rd Jun 2013 at 21:33
blandy
Looking good how much did the doors set you back? And how much weight do you think you've saved
pete_rallye
The door skins were £50 each, he also does full f/g doors. Nt sure yet about fixing the door handle, guess the mechanism will just be bonded in place.
In total I've probably saved about 12-15kg from each door with polycarb windows, getting rid of the window motor etc etc
There is a lot of weight in the hinge area as the metal is thicker so going to look at trimming that back, although I can't see there been more than half kilo at most. The hinges themselves are quite thick...
Lap of the 'ring
Posted 23rd Jun 2013 at 21:37
A carbon item will be approximately half the weight, why can't he do one of those?
pete_rallye
I agree about carbon in weight saving, but I don't really want to take a £500 bonnet or £300 door skin or something racing for the sake of a couple of kilos, if that! Rather stick with cheaper stuff then when you have the inevitable knock or bump its not a major cost.
Lap of the 'ring
Posted 23rd Jun 2013 at 21:40
fordygti
Post #35
We have done carbon before for a few small bits like bashes etc, but hant got an oven to harden it up,
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 23rd Jun 2013 at 21:50
fordygti
Post #36
Thought fibre worx were doing carbon panels?
Posted 23rd Jun 2013 at 21:51
superchargedblack1997gti6
Post #37
They are. but he has a backlog of orders to complete first.
Posted 24th Jun 2013 at 11:40
Post #38
there's some very nice detail on this Rallye build about how he went about making the doors work
http://106owners.co.uk/forums/showthread.php?209769-My-Yellow-106-Rallye-Race-car-build/page7
might have toi go back a page or two to see how it was mounted.
Posted 24th Jun 2013 at 11:47
Pages (2): 1 [2]
