Author Subject: torsion bars pug 306
prparke
hi ive got a 306 with gti 6 rear beam and gaz coilovers wanting it slightly more firm but not rock hard, what torsion bar should i get? What is a standard size diameter gti 6 torsion bar?
Posted 30th May 2013 at 00:49
beez_neez_gt
Try Citroen Xsara VTS bars.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 30th May 2013 at 00:57
Standard are 20mm bars. Xsara vts bars are 21mm. Do you not have an up rated anti roll bar? Keep an eye out for a hybrid rear bar they make more difference than 21mm bars IMO. I've had both.
Mthere have also been group buys for 22 23 and 24mm bars I believe.
Posted 30th May 2013 at 07:41
jord294
If running coilovers with spring rate over 195lbs, I would recommend 22mm upwards for torsion bars.
Give us more info, so we can give more definitive answers.
what are the spring rate on the gaz?
is the car a daily driver or track car?
if you search, you will see that majority of people use b6 bilsteins and eibachs with 21mm torsion bars as a daily driver fast road/track set up
Posted 30th May 2013 at 08:22
Yup. As Andy knows that was my setup, 21mm bars B6 shocks solid mounts and hybrid ARB. But now I've stripped the car 21mm felt a bit bouncy to me so went for standard 20mm bars on my shiny new axle he built me. Though I think my b6's are getting somewhat tired now.
Posted 30th May 2013 at 10:06
prparke
have not uprated anti rollbar yet but plan to do so. do you think a 23mm torsion bar would be to stiff for road use?
what size is the standard anti rollbar for the 306?
Posted 30th May 2013 at 18:20
Personally I'd say so I find a stiff rear end jumps out over bumps round corners very easily but I know people who run 23's.
Posted 30th May 2013 at 19:37
depends on your damper budget Thumbs up
Posted 30th May 2013 at 19:51
Depends on the weight in the rear and what you intend to do with it.
Mine has f-all weight in the back so I run standard bars. Might go bigger at some point, but like it as it is tbh.
Posted 30th May 2013 at 20:13
Niall
I used to run 22.5mms and i found it too hard for these roads. It used to be very sketchy if cornering on a rough surface even at normal speeds.
Posted 30th May 2013 at 22:29
beez_neez_gt
Well since you only wanted them a little harder then VTS ones will do the job, although you could get some b6 bilsteil rear shocks with standard bars as mine ie 205 is quite firm now.
Pug fee`ver,
Posted 30th May 2013 at 22:36
