Author Subject: ABS light on...
pooouk
I changed the drivers side hub yesterday and now the ABS light won't go out!? The new hub has a different sensor (not new) in it and my ABS worked fine before. I cleaned the ring on the driveshaft with a wire brush and the tip of the sensor is perfectly clean. I have just been out the check the resistance as per the guide posted on here and that checks out (fluctuating between 1650 & 1400 ohms when the wheel is spun) and it gives identical readings to the sensor that came off the car in the other hub. I've not touched any other part of the ABS system, just the drivers side front that I have been working on. I've driven a good few miles in it as well, as I read that the system will reset once above 8mph.
Is there anything obvious that I'm missing??
Cheers,
Nick
AKA nick on 205gtidrivers.com
Posted 16th Jun 2013 at 12:37
pooouk
No one got any ideas????
Nick
Posted 17th Jun 2013 at 10:03
Rich E Forum Admin
Check the obvious things, if you haven't already, such as sensors plugged in, fuses, damaged cables, etc..
If that's all okay then I'd swap back to your known good sensor, and if it's still not working with that refitted then that suggests the ABS ring has been disturbed in some way meaning it's not triggering the sensor correctly.
Posted 17th Jun 2013 at 12:07
Were you checking at the sensor plug or the abs unit plug?
Posted 17th Jun 2013 at 13:03
pooouk
I have checked the sensor plug for resistance on both the old (known working) one and the new one. Both were coming up with identical values and were in the range that are given in the "ABS Checking" thread. I've not checked the abs unit yet, as I've not disturbed that, but worth a try. I'm leaning towards the abs ring being too corroded, I wire brushed it and have probably just taken too much rust off!!
Would the light still come on if it was a blown fuse, or would it just not come on when the ignition was switched on??
Cheers,
Nick
Posted 17th Jun 2013 at 15:12
Rich E Forum Admin
Yes, the ABS light is on by default and the ABS unit has to switch it off if the system is healthy.
Unplugging the ABS unit, for example, will bring the light on.
Posted 17th Jun 2013 at 16:29
I'd check form the abs unit plug, you've ascertained that the sensors are good, but not the rest of the ABS loom.
Posted 17th Jun 2013 at 18:11
mechanical_repairs
As said above, check the resistances now at the main abs harness plug.
Carl
Posted 17th Jun 2013 at 19:22
pooouk
I'll give it a go, but strange that all that I've done is change the hub and now it's gone from fully functioning to not!! Would rather not be spending another Saturday underneath it so will test the rest of it.
Cheers,
Nick
Posted 17th Jun 2013 at 20:29
footah212
I've done all the resistence checks too and the ABS still doesn't work, never has.
Take the bulb out . Feck the ABS!!!
It has passed 3 mots since then too.
Thumbs up Thumbs up
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 17th Jun 2013 at 22:04
jamiek_uk2000
Thumbs up Thumbs up
I've done that on a Saxo before, with my 306 though I've just put a new driveshaft on and it has sorted it. The old ring had come clean off, so that may have been an issue LOL
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 17th Jun 2013 at 22:26
