| Author | Subject: Timing pins |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
Anyone know where to get a set? All ive found so far is big sets for various engines which are well over £100 yet there seems to be plenty of other sets for other engines for about £20-30. |
For the J4RS?Visit your pot of drill bits ________________________________________ ![]() |
6 and 8mm rod is available from metalsupermarket________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
beez_neez_gt
8mm drill ends smooth end.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Niall
Problem is when ive done that before, what may fit nice and snug in the hole in the head, is still not wide enough for the hole in the cam lobe (at least i dont think. Its been well over a year since ive done a gti belt) so the cam can still move a bit |
beez_neez_gt
Iirc I used an 6mm bolts n screwed them in last time.6 not 8mm lol. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Niall
Fair enough. Annoyingly, cambelt was only done a year ago but the pump has started making some funny noises so got an original pug one. Just need to order a new belt and coolant and jobs a good'un! |
Rich E
I made a pair of cam pins from a couple of old thermostat housing studs, and just cut the thread off on the short end.For the crank pulley I did the same with a shanked 8mm bolt, but I don't remember where that came from. ________________________________________ Rich |
I hired a proper Gates set from my local factors - £9 for a week and I did both XU engined cars with it ![]() ________________________________________ Nothing to see here |
Thats a good idea, shame more dont do that, i have two valve stems cut to length for the cams and the shank of s bolt with no threads for the crank.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
I used to use 8mm drill bit for the crank and 2x6mm bolts for the cams. I now have an array of different French timing pin sets at work inc tools to lock the flywheel easy etc. soooo much easier lol ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
stan_306gti6
Yep, I've got 2 x 6mm drill bits cut down, plus an 8mm bolt for the crank pulley. Plus I also have a known good crank pulley which I use when doing belts so I know the timing will be correct.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
