The cup that they go into in slightly distorted, and as I have roller bearing wishbones, I can't really tighten them up to the recommended torque rating of one white elbow.
Any suggestions? New subframe time? I'm thinking I might go this route
| Author | Subject: Front wishbone bolts |
gilesy
Seasoned Pro Location: Greenwich - in that London Registered: 03 Apr 2006 Posts: 5,133 Status: Offline |
These bad boys keep undoing themselves slightly, and I keep needing to get back under there and nip them back up. The cup that they go into in slightly distorted, and as I have roller bearing wishbones, I can't really tighten them up to the recommended torque rating of one white elbow. Any suggestions? New subframe time? I'm thinking I might go this route |
No reason why they cannot be torqued up properly at all.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
As aboveCan't see what difference a new subframe will make Get new bolts and the square nut that is sat in subframe, and if you want peace of mind put some thread lock on them ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
gilesy
Well I have a 2ft bar and they have previously been done up so tight that it has distorted the cup that the wishbone sits in, to the extent that I couldn't get the washers in for the solid mountsThink new bolts and thread lock is what's needed. |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Mine also wound their way out, loctite!________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
How did you get on?________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
daver6
Well it turns out that mine is now f**ked and needs the bolt and captive nut replaced________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
