Author Subject: Swapping boot lids
About to go outside and attempt the above.
Any advice on removing, any potential pitfalls?
What about the wiring and rubber gromet thing?
Any advice/skills much appreicated
Posted 18th Jun 2013 at 11:45
birk
Dont do it on your own.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 18th Jun 2013 at 11:15
Haha yeah think that ones a given as I would gave f all change of holidng it steady and tightening it up :p
Posted 18th Jun 2013 at 11:21
superchargedblack1997gti6
I changed one on my own the other day just put a towel on the boot lip so that you can rest it whilst doing the first bit. take you about half hour if you have a decent buzz gun!
Posted 18th Jun 2013 at 11:31
russbez
yeh iv also done it with towels alright
would be a lot easier to use a steady friend
getting the rubber grommets in place were a pain iirc
My Rallye project thread
Posted 18th Jun 2013 at 12:18
How do you remove the rubber gromets to take of the existing one?
JUst pull?
I assume that theres a connector underneath to disconnect?
I also assume its better to remove from the boot end rather than the shell?
Posted 18th Jun 2013 at 13:51
You need to remove/loosen rear right hand side trim, 3 connectors hidden behind it. Pull rubber out then feed the connectors through one by one, this is a faf and small fingers/patience helps. You'll need to sort the wiper pipe out too which feeds in under the roof lining iirc there is a connector that joins into the boot.
Posted 18th Jun 2013 at 14:00
FML this sound like more of a faf than i thought.
Think ill leave it for tomorrow now as im off out at 5
Cheers for that thug Smile
Posted 18th Jun 2013 at 14:05
right so ive just started this now, think ive got it all clue up now and sorted (What a faf with all the boot trim though!)
Question,
New boot has no wiper arm on it.
It has the nut attached with a broken bit of plastic, JUst to check, it is a normal lefty lossy righty tighty nut right?
ANd not a reverse thread
Posted 22nd Jun 2013 at 14:09
smegal
Question,
Yeah, just a normal nut.
Ex SC-6
Now in a Megane R26
Posted 22nd Jun 2013 at 14:27
beez_neez_gt
Did u just unplug the wiring from central locking n wiper motor etc then when old boot was off the wiring came out then u fed it back through, or is there a plug link inside the roof lining area like the water pipe?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 22nd Jun 2013 at 14:33
I was just going to re connect the wiring from the new boot, bascially juts what thug said.
Anyways, As it turns out i prepped the whole car, removed all the connections and fed them all out and finally was ready to un bolt the old one, Then when i let the new "pretty much mint" boot down on the ground, It had three dings in the bottom of the panel, A chip in the edge and two slight creases along the top edge.So basically not wirth doing.
To say i am miffed is an understandment, When i looked at the packaging i realised it wasnt missing the wiper arm at all rather it was led in the bottom of the box snapped.
Wasted about 2 hours then..
Posted 22nd Jun 2013 at 18:40
