Sorry if its a dumb question but I hate electrics.
Thanks chaps
| Author | Subject: airbag resistor use |
greenie
Regular Location: Sandhurst Registered: 06 Feb 2013 Posts: 227 Status: Offline |
Just removed the passenger airbag and replaced it with an upper glove box. I know I need a 1.8 ohm resistor to fool the ecu but is as simple as just plugging it in where the airbag used to be plugged in ?Sorry if its a dumb question but I hate electrics. Thanks chaps |
Matt_rallye
Regular Location: Bournemouth Registered: 09 Jul 2012 Posts: 468 Status: Offline |
Give cully a pm on here or on 306oc he knocks up little resister kits for a small price |
greenie
Oh ok, thanksI actually have the fused resistor ready to go. I just need encouragement that you just plug it into the orange connector in place of the airbag ! |
Matt_rallye
I believe that's the way you do it, cully also did a guide over on 306oc |
greenie
Nice one, thanks |
This is the lad you want: http://www.306gti6.com/viewprofile.php?id=22585 ________________________________________ ![]() |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
correct. Just bridge the two pins on the plug (with the car off obviously) and job done! |
greenie
Ace all done.Cheers fellas. |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
that would be me then !1.8ohm resistor plugged in were the bag once was should help use a fused resistor though it will protect the rest of the system by not overloading the electronics in the airbag ecu on detination ,the fuse will blow instead ![]() 1.8 works on PH3 i measured bags at 2.7ohm on a ph2 but have used 1.8's on these systems too i have listings on ebay for 1.8 2.2 2.7 3.3 search for ebay seller cu11y70 |
Niall
cully wrote: that would be me then ! 1.8ohm resistor plugged in were the bag once was should help use a fused resistor though it will protect the rest of the system by not overloading the electronics in the airbag ecu on detination ,the fuse will blow instead ![]() 1.8 works on PH3 i measured bags at 2.7ohm on a ph2 but have used 1.8's on these systems too i have listings on ebay for 1.8 2.2 2.7 3.3 search for ebay seller cu11y70 ![]() But the airbag ecu is only single use. Once its detonated one bag, it needs replacing. Unless your thinking the return voltage will detonate another air bag? |
cully
the idea for using a fused resistor is it acts like an airbag!if you just put a resistor link in its place it may take all the current designed for say 6 bags so only 1 or two bags might detinate insted of all the intended |
Niall
Ahhh i see. |
greenie
It is your good self that I just purchased some from on the bay then ! |
cully
yes i think soif you ordered yesterday they were posted first class today |
beez_neez_gt
Can u send us an ebay link please ?So do all of the air bags need one or can u just fit one to any with others still working ? ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
beez_neez_gt
cully
beez_neez_gt wrote: Can u send us an ebay link please ? So do all of the air bags need one or can u just fit one to any with others still working ? you only use a resistor on the loom ends where you removed the bag/pretensioner from you dont need to fit to any other bag that you want to still work search for ebay seller cu11y70 or search "airbag resistor" and look for the value resistance you need there are other sellers who sell them so the choice is yours who you buy from |
beez_neez_gt
Ok thanks, iv never searched for a member before so not sure how to.I have a phase two 98 car but may have ph3 airbag for all I know, could have been changed. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
cully
