Author Subject: Door to car plug
Ed_van_dijk
Im on the understanding that you can get a new plug, I have a broken wire right where it joins the plug which is my speaker wire.
Where can you get a new plug or is there a way of repairing the current one?
Astor 6
Posted 20th Jun 2013 at 14:07
Drivers side? I may have an inner door loom and plug knocking about actually which you could swap over if it was the same.
  • Posted 20th Jun 2013 at 14:12
    Ed_van_dijk
    no its a passenger side chap. if you did that would be brilliant
    Astor 6
    Posted 20th Jun 2013 at 14:13
    Ed_van_dijk
    Also if anyone wants to make this in the electrical section for me? Engines and electrical are too close together lol
    Astor 6
    Posted 20th Jun 2013 at 14:15
    In that case I've a pass door which I can remove the lot from. 2000 ph3 so should be the same as yours Thumbs up
  • Posted 20th Jun 2013 at 14:22
    Ed_van_dijk
    that would be fantastic, inbox me your pay pal details and how much you want
    Astor 6
    Posted 20th Jun 2013 at 14:23
    Ed_van_dijk
    its the car side of the plug not the door, if that makes sense
    Astor 6
    Posted 20th Jun 2013 at 14:24
    most people just ditch that part with the car after being broken,..
    and i suspect that will be with the main wiring loom too?,.. may be a case of stripping back the car to get to it po it out remove the pin from the inside and re solider
    all guess work like! Dunno
    Posted 20th Jun 2013 at 14:32
    Ed_van_dijk
    Yes it is with the main wiring loom but you could cut them back at the plug and lengthen them and put a new plug in
    Astor 6
    Posted 20th Jun 2013 at 14:33
    Once again you are in luck as I have one of those too LOL
    You'd best like soldering!
    I'll gather up what I have tonight and we'll work something out.
  • Posted 20th Jun 2013 at 14:34
    Ed_van_dijk
    thanks pal, my girlfriend's dad likes soldering, the amount of time i have cut his grass its the least he could do lol
    let me know Smile
    Astor 6
    Posted 20th Jun 2013 at 14:36
    now that's an understanding Prospective farther in law! LOL
    Thumbs up
    while where in the subject of wires,..
    I need some wire with plugs for the mirror cover tweeters that cam on some of the later 306's
    got any of those Dan?
    Posted 20th Jun 2013 at 14:40
    Unfortunately not Dave. The last Ph3 I did had the tweeter covers but the wires had been butchered at some point.
  • Posted 20th Jun 2013 at 16:40
    never mind I'll be doing some butchering of my own
    i just need those connectors for the tweeters themselves! Thumbs up
    Posted 20th Jun 2013 at 16:43
    Ed_van_dijk
    I may have some at home Dave. Ill have a look when i remember!
    Astor 6
    Posted 20th Jun 2013 at 16:45
    cully
    make sure you count the wired pins on you car and make sure the plug/wires your buying has the same or more pins connected
    as different models have used different looms for electic extras Wink
    Posted 20th Jun 2013 at 19:38
    Thumbs up! Legend!
    Posted 21st Jun 2013 at 09:46
    gnrlee wrote:
    Thumbs up! Legend!
    but id presume that these would be a different colour?
    surly it would just be a case of matching the colour wires?
    but if not then painstakingly clipping the wire from one plug and soldering it to the same point on the plug to where the original wire was if you get me? Crazy
    just don't get it wrong or your windows will be going up and down to the beat of the music LOL
    Posted 21st Jun 2013 at 09:49
    Never go on colours when matching Peugeot wiring. Go on the numbers printed on them.
    As mine is a GTi6 loom it may well be the same, Ed is going to cross reference to be sure.
  • Posted 21st Jun 2013 at 10:45
    cully
    as said dont rely on the wire colours you will find multiple wires of the same colour
    peugeot used wire numbers
    i have a drawing on the plug pin numbers and wire numbers that may helps you its for a Hdi with all pins connected Wink
    Posted 21st Jun 2013 at 11:38
    mattgti6phase2
    I am in need of the above. I chopped in a new loom and got the major things working, but now I'm stuck with 9 wires 2 green 3 red 3 light brown and I can't remember the other. I don't know what they bloody do though!
    So in short I need to find which ones do the central locking, the electric mirror and the outside thermometer and I think that's it Roll eyes
    Team Nile 6 Superman
    Team: 40.2 MPG Smile
    5 x a 306 owner!
    I truely live for the 306 ®
    midweek madness Tee hee
    Posted 28th Jun 2013 at 00:45
    Moved to Electrical. Smile
    Posted 28th Jun 2013 at 07:20
    cully
    these drawings are for a ph3 hdi but should be good
    Offside drivers door
    Near side door with Temp sensor
    Posted 28th Jun 2013 at 08:18
