Shall know within the hour whether its a pass or fail!!
Richies Project RallyeElectrical work carried out in Portsmouth
| Author | Subject: Gaaah so nervous!! |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
My baby is in for her first MOT under my care!! Shall know within the hour whether its a pass or fail!! ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
Well it's been over an hour. How long's the list?________________________________________ ![]() |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Good luck Rich. Let us know how it went. ________________________________________ Cherry Rallye SOLD |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
It passed! |
playboyb
Seasoned Pro Location: Maidstone Son! Registered: 27 Jun 2011 Posts: 1,464 Status: Offline |
Niall wrote: It passed! Advisories? ![]() ________________________________________ 306 1.8 xs moonstone blue-SOLD306 gti6 supercharged china blue-SOLD 406 coupe D9 3.0 V6-SOLD |
rich306
Yeah, it passed with 5 Advisories: 1 - Windscreen has damage to an area less than 40mm circle outside Zone A 2 - Power steering component has slight seepage. 3 - Offside brake juddering Slightly 4 - N/S/F (rear bush) Suspension arm has slight play in a Pin/Bush 5 - Front brakes only just met the front brake imbalance requirements. It would appear that the braking system requires adjustment or repair. number 5 is as a result of number 3. The tester reckons that the disc overheated at one stage when new therefore warping the disc. ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
rallyeash
All simple stuff then!________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
Mine passed today too, managed to behave itself for long enough ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
Mine failed the other day on emissions, new cat it is! Apart from that the old girl was ok.Tis a nervous time MOT time |
rich306
I won't be so bad next year, mainly because i tend to address the issues before-hand. ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
stan_306gti6
rallyeash wrote: All simple stuff then! You say that, but I reckon that the suspension arm play in the pin/bush will take longer than 5 minutes to sort. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Niall
woody. wrote: Mine failed the other day on emissions, new cat it is! Apart from that the old girl was ok. Tis a nervous time MOT time You say that, i had a right nightmare of a time getting my old 1.8 through a emissions test. Did the cambelt on it and who ever timed it up before i had it clearly worked by the "that will do" Method. Timed it up properly (was a fair way out) and it passed very very well! |
rich306
stan_306gti6 wrote: rallyeash wrote: All simple stuff then! You say that, but I reckon that the suspension arm play in the pin/bush will take longer than 5 minutes to sort. ![]() I'm trying to picture exactly where this is... ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
rich306 wrote: stan_306gti6 wrote: rallyeash wrote: All simple stuff then! You say that, but I reckon that the suspension arm play in the pin/bush will take longer than 5 minutes to sort. ![]() I'm trying to picture exactly where this is... Beam rebuild time ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
jimmyrallye
Seasoned Pro Location: portsmouth Registered: 19 Apr 2008 Posts: 3,144 Status: Offline |
^ yep ________________________________________ "Police arrested two kids yesterday, one was drinking battery acid, the other was eating fireworks. They charged one and let the other one off." |
stan_306gti6
Which is what I meant about not being a 5 minute job. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
You say that________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
Isn't it just the P bush thats the issue? N/S/F tells me its the front end of the vehicle thats the issue, rear bush being the P bush. Still not a 2 minute job though. ![]() ________________________________________ Goldie the track car. |
rich306
Now I know, it's nothing to do with the rear beam. wishbone stuff! Hehe________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
stan_306gti6
![]() I just read the bit about 'rear bush' and completely missed the 'N/S/F'. ![]() Yep, just a P bush so no need for much drama. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Keep up Stan FFS.________________________________________ ![]() |
stan_306gti6
dangti6 wrote: Keep up Stan FFS. Calm down dear... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rich306
haha, rear beam needs a rebuild anyway ![]() ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
Got a donor beam you can have to cheap if it helps? Bit far from you though ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
rich306
Lol I'll be doing the rear beam when I have a van to drive around in so bearing Kit will be on order. Thanks anyway ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
