Author Subject: OEM Airbox and pipework and side skirt seals
raunchz
Hi all,
I've just bought a rallye and I'm after an oem airbox setup - ideally after everything from the throttle body to the intake snorkel which sits over the slam panel? Ideally if you've got the bolts to go with it that'd be ideal, but no cruicial Thumbs up
I'm in leamington spa area so anyone local'ish would be ideal - otherwise can pay for postage.
Plus I'm after those black seals which sit between the side-skirt and the shell underneath the door - after both side is possible.
Thanks in advance - pm me if you you've got either of the above.
Posted 28th Jun 2013 at 12:48
raunchz
Im also after a ptfe inlet manifold gasket if anyone has one
Posted 28th Jun 2013 at 19:54
raunchz
Oem airbox sourced.
Just after ptfe inlet gasket and door seals.
Posted 30th Jun 2013 at 15:25
mik
Ref sill seals see here:
http://www.306gti6.com/forum/showthread.php?id=155502
Best bet is ebay.
Cherry Rallye SOLD
Posted 30th Jun 2013 at 15:38
raunchz
Best bet is ebay.
Awesome thanks, might need to rethink refreshing the current seals Dunno
Posted 30th Jun 2013 at 16:19
