Author Subject: Front bumper sag
darzmat
Anyone sorted their sagging front bumber?? If so what did u do??
I dont know where to start with it tbh, but its really anoying me.
Thanks
Posted 1st Jul 2013 at 23:55
jimmyhackers
take it off. and heighten every mounting point by whatever mm your sag gap is.
you may have to do some prehand thinking and studying to desipher if and how you need to raise some more than others.
ballache it is. with chipped paint and very poor metal working skills i did it. the results underneath wernt pretty but they get covered up by the bumper, looks grand so alls well
Posted 2nd Jul 2013 at 00:36
JWP EFi
Turbo Legend!
it needs a bra
Posted 2nd Jul 2013 at 07:29
Has your bumper still got the three mounting straps attached to it underneath?
I suspect not.
Posted 2nd Jul 2013 at 10:27
russbez
I suspect not.
i would check this
good ole group n engine mounts used make my front bumper shake a lot
i noticed one of mine are broken off now too Doh
My Rallye project thread
Posted 2nd Jul 2013 at 10:41
in my experience its more important to get someone to lift it up wards as you are tighening it that anything.
You have to be quite rough with it.
Posted 2nd Jul 2013 at 10:45
matt evans
well padded block of wood on a gently worked trolley jack, just under the numberplate area of the bumper normally suffices as an extra third hand when tightening the bolts behind the slam panel
honestly3k wrote:
owain wrote:
Posted 2nd Jul 2013 at 10:55
gilesy
Gayest post of 2013 right there Shock Love
Posted 2nd Jul 2013 at 11:05
Laugh my ass off
Posted 2nd Jul 2013 at 11:54
Niall
I suspect not.
This. On my old bumper these were missing. I got 3 sepia of metal and tapped them to the bumper and crossmember, readjusted the bumper and looked perfect.
Posted 2nd Jul 2013 at 12:01
darzmat
Ive got at least two of the 3 straps at the bottom i cant remember off hand.
But i think the two inner bolts through the slam panel are missing/sheared/fallen into bumper/i broke them...
Might whip it off just now and see
Posted 2nd Jul 2013 at 13:50
It's these lower straps which keep it level and stop the sagging. These will be the issue. Yes
Posted 2nd Jul 2013 at 14:02
mik
I'm not sure about that - the three straps are as floppy and insubstantial as a politician's morals and would not keep the bumper straight or stop it sagging vertically as they will just bend. My new OE bumper has all 3 on there and to me it appears all they do is help position the lower lip longitudinally (from front to rear).
My repainted second hand bumper has a bit of a gap on the right side and as said above by Matt and Eliot I think it is more to do with positioning it correctly with helper or trolley jack and wood before tightening the nuts, and if necessary adjusting the white eccentric round bumper mounts on each side that provide a degree of vertical adjustment.
Cherry Rallye SOLD
Posted 2nd Jul 2013 at 17:32
Possibly, but the three straps have elongated holes in them to allow you to position the bumper where you want it before tightening up the bolts. Yes
This is the way I've always done it and then finally tightened the main bumper fixing bolts. Smile
Posted 2nd Jul 2013 at 19:03
jimmyhackers
the other solution. could be to remove your bumper
hang it upside down and very carefully with a heat gun, heat the top edge to get it to sag in the opposite direction. this should work if your extra careful.
if you over do it you could bubble your paint or end up with a bumper that looks like an escher painting.
Posted 2nd Jul 2013 at 23:37
Blink
Posted 3rd Jul 2013 at 08:59
No worries,
I actually need to take the bumper off again soon.
Maybe you can be the one giving it stick when the time comes ? Love
Posted 3rd Jul 2013 at 09:07
